Compiling gcc-3.2.2 (HOWTO)
Unread postby nekonoko » Wed Feb 12, 2003 9:23 pm
Not sure how many of you are using gcc-3.2.1 from SGI's Freeware (as it requires IRIX 6.5.18+ due to the header changes), but his may help some.
I discovered a nasty bug with g++ which made it useless for even those using 6.5.18. Yes, once again an issue with the new header structure ... a compile time option was left off by SGI that generates unresolvable errors during g++ compiles.
gcc-3.2.2 was released a couple of days ago so I decided to take advantage of the situation and repair the botched gcc-3.2.1 SGI Freeware version. It was pretty easy to get going.
Untar and change to gcc-3.2.2/:
./configure --prefix=/usr/freeware --enable-version-specific-runtime-libs --enable-threads --enable-haifa --disable-c-mbchar --disable-shared
gmake bootstrap
gmake install
[Mika:~] neko 105% gcc -v
Reading specs from /usr/freeware/lib/gcc-lib/mips-sgi-irix6.5/3.2.2/specs
Configured with: ./configure --prefix=/usr/freeware --enable-version-specific-runtime-libs --enable-threads --enable-haifa --disable-c-mbchar --disable-shared
Thread model: single
gcc version 3.2.2
That's it!
I just tried it on code that was killing me under 3.2.1 and I'm now getting clean compiles :)
BTW, you can use the same method to install 3.2.2 on IRIX 6.5.17 and below, just leave off the --disable-c-mbchar switch on the configure line.
Shtoink
Unread postby Shtoink » Fri Feb 14, 2003 6:52 pm
/me needs to figure out how to get ahold of 6.5.19f some how... :cry:
Unread postby nekonoko » Sat Feb 15, 2003 4:05 pm
Shtoink wrote:/me needs to figure out how to get ahold of 6.5.19f some how... :cry:
You don't need 6.5.19 to compile 3.2.2, 6.5.19 just needs an extra switch to do so is all.
ian
Unread postby ian » Mon Feb 17, 2003 12:59 pm
why do you want a feature release? it only contains unsupported software for sgi customers who want to live dangerously ;)
psergiu
Unread postby psergiu » Tue Feb 18, 2003 10:47 am
Also take note that this is 6.5.19 - and as we all linux users know - this is the unstable version. Better stick with 6.4 :twisted:
Shtoink
Unread postby Shtoink » Wed Mar 05, 2003 10:42 am
I like the little disclaimer about gcc 3.2.1 on the freeware site.
NOTE: fw_gcc/3.2.1 should only be used on systems running IRIX 6.5.18 or later. It accidentally picked up some version-specific headers. Older system can still run fw_gcc/3.0.4
Accidentally, eh?
