Fuel R16000/700Mhz/2GB/V12
Oskar45
Unread postby Oskar45 » Fri Dec 09, 2005 1:28 am
Hi, everyone...
Firstly, all the hard facts about my current FUEL:
IRIS 1 # hinv -vm
            IP34 Board: barcode MLD178     part 030-1707-004 rev -C
        IP34PIMM Board: barcode MXA490     part 030-1891-001 rev -D
          ASTODY Board: barcode MDB639     part 030-1996-001 rev -A
1 700 MHZ IP35 Processor
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0xa
Main memory size: 2048 Mbytes
Integral SCSI controller 3: Version LS1030, low voltage differential
Integral SCSI controller 2: Version LS1030, single ended
  Tape drive: unit 5 on SCSI controller 2: DAT
  Disk drive / removable media: unit 6 on SCSI controller 2: 720K/1.44M floppy
Graphics board: V12
Iris Audio Processor: USB audio revision 1.0, number -1
  PCI Adapter ID (vendor 0x1000, device 0x0030) PCI slot 3
USB controller: type OHCI
IRIS 2 # /usr/gfx/gfxinfo
        Managed (":0.0") 1600x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: SGX 512
         Video Output: 1600 pixels, 1200 lines, 75.00Hz (1600x1200_75)
IRIS 3 # l1cmd --scdev /hw/module/001c01/L1/controller version
L1 1.34.14 (Image B), Built 03/01/2005 10:23:31    [Fuel/PE 1MB image]
IRIS 4 # l1cmd --scdev /hw/module/001c01/L1/controller env
ATTENTION: Environmental monitoring is disabled!
           12V   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.188
        12V IO   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.312
            5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.070
          3.3V   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.320
          2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
          1.5V   Disabled  10%   1.35/  1.65  20%   1.20/  1.80    1.466
        5V AUX   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
      3.3V AUX   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
 PIMM 12V BIAS   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.312
          SRAM   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.509
          VCPU   Disabled  10%   1.13/  1.38  20%   1.00/  1.50    1.255
     PIMM 1.5V   Disabled  10%   1.35/  1.65  20%   1.20/  1.80    1.495
 PIMM 3.3V AUX   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.285
   PIMM 5V AUX   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.096
  XIO 12V BIAS   Disabled  10%  10.80/ 13.20  20%   9.60/ 14.40   12.125
        XIO 5V   Disabled  10%   4.50/  5.50  20%   4.00/  6.00    5.044
      XIO 2.5V   Disabled  10%   2.25/  2.75  20%   2.00/  3.00    2.470
  XIO 3.3V AUX   Disabled  10%   2.97/  3.63  20%   2.64/  3.96    3.302
FAN  0  EXHAUST   Disabled          920         1240
FAN  1       HD   Disabled         1560         2295
FAN  2      PCI   Disabled         1120         1506
FAN  3    XIO 1   Disabled         1600         2327
FAN  4    XIO 2   Disabled         1600         2250
FAN  5       PS   Disabled         1349         2860
 0 NODE 0            Enabled    [Autofan Control]    80C/176F   36C/ 96F
 1 NODE 1            Enabled    [Autofan Control]    80C/176F   37C/ 98F
 2 NODE 2            Enabled    [Autofan Control]    80C/176F   28C/ 82F
 3 PIMM              Enabled    [Autofan Control]    80C/176F   41C/105F
 4 ODYSSEY           Enabled    [Autofan Control]    80C/176F   43C/109F
 5 BEDROCK           Enabled    [Autofan Control]    85C/185F   41C/105F
IRIS 5 # uname -aR
IRIX64 IRIS 6.5 6.5.28m 07010238 IP35
IRIS 6 # configmon -i
REC_KEY       SYS_ID SYS_TYPE SERIAL_NUMBER      IP_ADDRESS HOSTNAME
      0   1762687396     IP35  0800691079A4       10.0.0.10 IRIS
IRIS 7 # configmon -h
  SEQ            NAME      LOCATION          SERIAL_NUM   PART_NUMBER  REVISION
    0              NA            NA                  NA            NA        NA
    1   MODULE_001c01            NA                  NA            NA        NA
    2              L1        001c01                  NA            NA        NA
    3            IP34        001c01              MLD178  030-1707-004        -C
    4       MEMBANK_0        001c01                  NA            NA        NA
    5       MEMBANK_1        001c01                  NA            NA        NA
    6          R14000        001c01                  NA            NA        NA
    7              NA        001c01                  NA            NA        NA
    8            IP34        001c01              MLD178  030-1707-004        -C
    9          ASTODY      XTALK_13              MDB639  030-1996-001        -A
   10            IP34      XTALK_14              MLD178  030-1707-004        -C
   11     SCSI_CTLR_0            NA                  NA            NA        NA
   12         DRIVE_1            NA            3EK1HAMH    ST373405LW      2744
   13     SCSI_CTLR_1            NA                  NA            NA        NA
   14         CDROM_4            NA                  NA            NA        NA
   15     SCSI_CTLR_2            NA                  NA            NA        NA
   16          TAPE_5            NA                  NA            NA        NA
   17     SCSI_CTLR_3            NA                  NA            NA        NA
   18    ETHERNET_EF0            NA                  NA            NA        NA
Secondly, my observations/? [in no particular order]:
1. With the iMic-based audio option purchased from SGI, I got
Iris Audio Processor: USB audio revision 1.0, number 0
Since my iMic failed, I got from SGI an official replacement, called TELEX, but after installation, although it works ok, now I get
What does "number -1" exactly mean?
2. Why do I get the following two /equal/ entries in <hinv -vm>, although I've nothing at all plugged-in:
3. I disabled environment monitoring because after installing 6.5.28m, I got configmon (included in ESP) core dumps after /every/ startup; SGI's temporary workaround is
#configmon -Sk /* resulting in loss of ESP hardware/software configuration data */
or
#chkconfig esp off
Since I don't really need ESP anyway, I'd disabled it [of course, once SGI has fixed the problem, I'll enable it again].
4. Why does <configmon -h> show R14000 [in SEQ 6] and not R16000?
5. Seems SGI is confused: plain <hinv>, <uname -aR> and <configmon -i> all show IP35 [which actually is for an Origin3000 proper] instead of IP34 [as in <configmon -h> or <hinv -vm>] which would be correct for a FUEL [of course, the FUEL is an Origin3000 derivate, but still: if you would need a replacement, IP35 would be wrong].
Thanks.
/oskar
C is opium for programmers.
Re: Fuel R16000/700Mhz/2GB/V12
Unread postby nekonoko » Fri Dec 09, 2005 10:35 am
Oskar45 wrote:2. Why do I get the following two /equal/ entries in <hinv -vm>, although I've nothing at all plugged-in:
Well looking at the PCI database, that's a LSI Logic LSI53C1020/1030 PCI-X to Ultra320 SCSI Controller, which of course makes sense due to this part of your hinv:
So it looks like you've got some kind of additional SCSI card installed in there since this is in addition to the standard built-in QLA12160 U160 channels (which your hard drive/optical drive are currently connected to). Kind of interesting actually as I wasn't aware of any U320 cards that worked on IRIX before now - looks like the LSI Logic LSI21320/LSI22320 cards would be a strong candidate for further experimentation :)
Oskar45
Unread postby Oskar45 » Wed Dec 14, 2005 6:12 am
nekonoko wrote: Kind of interesting actually as I wasn't aware of any U320 cards that worked on IRIX before now - looks like the LSI Logic LSI21320/LSI22320 cards would be a strong candidate for further experimentation :)
Well, I did make some inquiries with SGI support and learnt that the card is officially listed as
PCIX-SCSI-U4-2P
But since the Fuel PCI-bus is limited to 66Mhz, my card will most probably not run much faster than an U160. :(
As my Fuel was actually a demo machine before I got it, maybe the above card is just a left-over after some experimentation (instead of the normal PCI-SCSI-U3-2P).
schleusel
Unread postby schleusel » Sat Jan 07, 2006 4:47 am
nekonoko wrote: looks like the LSI Logic LSI21320/LSI22320 cards would be a strong candidate for further experimentation :)
hmm, scrolling through the strings output of the ls.o module:
1068 SAS/SATA
1064 SAS/SATA
949X fibre channel
939X fibre channel
929X fibre channel
1030 scsi
the first two might be fun to try too :-)
