A few icons
DaJuice
A few icons
Unread postby DaJuice » Wed Jun 15, 2005 3:47 pm
I drew a couple more icons. They're pretty fun to make actually. :D Aterm, deerpark, firefox, and xchat. FTR files not included.
note: the firefox one has been updated from the last one I posted.
http://www.geocities.com/stehrani3d/icons.tar.gz (Right Click > Save)
Hope you like them.
BetXen
Unread postby BetXen » Wed Jun 15, 2005 11:50 pm
Thanks a lot for your icons.
Can you please tell me how to link them to my shortcuts on the desktop? I've aleady tried some times ago, but without success, and I don't remember how to do that.
Best regards
Raphaël
DaJuice
Unread postby DaJuice » Thu Jun 16, 2005 5:01 pm
Hi there,
For each .fti icon file you will need a corresponding .ftr file. These ftr files should go in /usr/lib/filetype/install/ and the fti files should go in /usr/lib/filetype/install/iconlib/. Here is my firefox ftr for example:
TYPE firefoxExecutable
    SUPERTYPE Executable
    MATCH tag == 770069;
    LEGEND web browser
    CMD OPEN      /usr/nekoware/bin/firefox
    CMD DROP       /usr/nekoware/bin/firefox $SELECTED
    ICON           {
                   if (opened) {
                            include("../iconlib/generic.exec.open.fti");
                   } else {
                            include("../iconlib/generic.exec.closed.fti");
                   include("/usr/lib/filetype/install/iconlib/firefox.fti"):
Things to take note of:
Obviously replace the firefox part of "firefoxExecutable" with the correct name for a given app. If it were a script instead of an executable you'd write that instead.
Supertype: Either executable or script
Match tag numbers: First go to the directory of the executable/script that you want to give an icon, and check to see if it has a match number already. Use the command tag -q myapp to do this. Usually developers are supposed to tag their stuff and you should not use a number that has already been taken by another program, but it's not like there are a ton of apps on irix, and the chances of picking a random number that has already been used is small. I used "tag 770069 firefox" to give firefox that match number as you can see. Also make sure not to forget this guy at the end of the number ---> ;
Legend: what you type here is the description you get when you right-click > Get Info. A short description of the program.
The last part of the .ftr is self-explanatory. This is a bare-bones ftr, they can have more funtionality besides drag & drop added to them.
Once you have your fti & ftr files in place change directory to /usr/lib/filetype and make sure you're a super user (type su, and then give root password). Enter "make -u". After it has finished doing its thing, log out and then log back in. If everything was setup correctly your programs should now have shiny new icons. :)
BetXen
Unread postby BetXen » Fri Jun 17, 2005 2:30 am
Merci beaucoup!
I'll try this asap.
Raphaël
yoben
Unread postby yoben » Fri Jun 17, 2005 4:14 am
Oh, quelqu'un de plus qui écrit en français, quelle joie. :lol:
Just a question --> it is easy to find a application number tag ?
DaJuice
Unread postby DaJuice » Fri Jun 17, 2005 10:27 am
You mean like a database of them somewhere? I have no idea.
Unread postby nekonoko » Fri Jun 17, 2005 10:34 am
Good article on File Type Rules here:
http://www.microcosmos.co.uk/sectionarticle1.html
zahal
tag numbers
Unread postby zahal » Sat Jul 09, 2005 5:31 pm
Good question, I also tried to find a database of tag numbers a couple of days ago. I gave up and just used one, hopefully no other app I have installed uses it. So far so good. Nice to have realplayer8 on the IconCatalog with a custom made icon. BTW, has anyone tried to compile helixplayer?
PymbleSoftware
Re: A few icons
Unread postby PymbleSoftware » Sat Jan 29, 2011 6:22 pm
The above link is broken as geocities has been taken down and these are the icon files I found on my NAS.
And I a can not attach the file to the wiki.
R.
icons.tar.gz
(10.17 KiB) Downloaded 44 times
死の神はりんごだけ食べる
開いた括弧は必ず閉じる -- あるプログラマー
Twitter @PymbleSoftware
Re: A few icons
Unread postby nekonoko » Sat Jan 29, 2011 6:26 pm
The latest link to the tutorial above is here: http://jamesholden.net/sgi-articles/fil ... -tutorial/
