Realsoft 3D v5.1 for IRIX
nvukovlj
Unread postby nvukovlj » Mon May 16, 2005 5:57 am
Hi guys,
Just wanted to let you know that Realsoft have released v5.1 of Realsoft 3D for Irix.
The package is still Beta (same as the Linux version), but basically, this doesn't mean that it is any less stable, but it does mean that it lacks behind in release schedule than the Windows version.
The benefit is that a lot of the bugs found in the Windows version are fixed by the time the Irix release comes out, and that the Irix licence can also be used for the Linux version.
The Irix and Linux versions are also considerably cheaper.
If you want to find out about the features of v5, check out the following URL: http://www.realsoft.fi/news/v5/ and here: http://www.realsoft.fi/news/v5sp1/
Anyway, there is an 'eval' version available for download now (not time limited, but rendering res. limited) from here:
http://www.realsoft.com/updates/irix/packages/realsoft3d-5.1.25-beta-irix-mips.sh
Let me know if you encounter any problems.
Let me know if you like it as well. It would be good for Realsoft to know if anyone is interested in their keeping the Irix version going.
I'm helping out on that front (just minor aspects of the porting, so can't take credit for either the features or the bugs. :) ), and will keep doing that while there's interest, since I barely get to use it these days due to work commitments.
Nik.
irix2003
Unread postby irix2003 » Mon May 16, 2005 5:58 pm
Cool, will try :D
GeneratriX
Re: Realsoft 3D v5.1 for IRIX
Unread postby GeneratriX » Mon May 16, 2005 7:13 pm
nvukovlj wrote:Anyway, there is an 'eval' version available for download now (not time limited, but rendering res. limited) from here:
Hello Nik...
I've downloaded the file to give it a try.
I'll need to fill any form to get the evaluation license, or this is included by default with the installer? I've not tried to install the package by now...
Thanks in advance!
Cheers! ;)
nvukovlj
Unread postby nvukovlj » Tue May 17, 2005 2:02 am
Hi Diego,
Just install it. No eval. registration required. On installation, when it asks for key, just leave empty.
Nik
zappa
Unread postby zappa » Tue May 17, 2005 4:24 am
It's nice, however I'm running into problems with incompatible libpng version: I have 1.2.15 in my library search path, but you have dynamically linked against 1.0.x. I think it is better to link against a static libpng, I suspect that many users have upgraded their shared libpng, and your version is pretty old. Apart from that, it looks really nice :-)
EDIT: actually, IRIX (6.5.22 at least) itself provides version 1.2.15
Such bugs and goblins in my life!
(Taken from Hamlet)
nvukovlj
Unread postby nvukovlj » Tue May 17, 2005 8:21 am
@zappa
Thanks for that report.
I'll look into that.
Nik.
sum][one
Unread postby sum][one » Tue May 17, 2005 8:34 am
installed.. right click on the viewport.. select "wireframe"... (or shade if you're in wireframe)... booom.
man this proggy crashes with nothing here.. dunno it might be my Octane that is messy.. but i cant really use it for more than 5 mins without a crash.
cheers ;)
:: jean-claude
:: mimgfx dot com
assyrix
Unread postby assyrix » Wed May 18, 2005 1:50 am
Hello,
Can you please port Real3D to the Itanium as SGI doesn't give a shit about MIPS no more? Cheers.
nvukovlj
Unread postby nvukovlj » Wed May 18, 2005 3:53 am
sum][one wrote:installed.. right click on the viewport.. select "wireframe"... (or shade if you're in wireframe)... booom.
cheers ;)
Is that the only time it crashes, or are you seeing it crash in other situations as well ?
Can you tell me the spec of your Octane ?
I'll test this on my machine later this week. It wasn't a problem before, could be something that was introduced with this version.
Nik.
nvukovlj
Unread postby nvukovlj » Fri May 20, 2005 3:47 pm
An update has been released. Version 5.1.26.
Fixes a few bugs that were reported (not specific to the Irix version though).
Get it here:
http://www.realsoft.com/updates/irix/packages/realsoft3d-5.1.26-beta-irix-mips.sh
Nik.
nuts
Unread postby nuts » Wed Sep 23, 2009 8:57 am
I've installed realsoft 3D 5.1.26 beta, but when I wanna run it I've got Bus error due to an incompatible libpng version: I have libpng-1.2.8 and r3d required 1.0.15
GeneratriX
Unread postby GeneratriX » Tue Oct 06, 2009 7:25 pm
Very nice app. I've tried today the Linux x86_64 version with Ubuntu AMD64 9.04. I'll give it a try to the IRIX version at some point.
Unread postby foetz » Wed Oct 07, 2009 2:41 pm
had it running back then.
not bad for a free app :D
GeneratriX
Unread postby GeneratriX » Wed Oct 07, 2009 4:43 pm
foetz wrote:had it running back then.
Indeed, and it looks top quality!
I don't know how to use it for serious work, since I just know the basics, and I'm actually focussed to learn to use another app. But I'm interested since I think I have a use for this one too! :)
With a bit of luck, I'll have my IRIX box running again soon.
competentcompton
Unread postby competentcompton » Thu Oct 08, 2009 2:23 pm
Hi,
I know that this topic is a bit old but seems that this link no longer works.
Did anyone download it? Or is a new link available?
Cheers
