Software raid on IRIX?
Thaidog
Unread postby Thaidog » Fri Apr 15, 2005 10:32 am
Does IRIX come with software raid? (Is there a way to configure software raid on IRIX?)
unixmuseum
Re: Software raid on IRIX?
Unread postby unixmuseum » Fri Apr 15, 2005 10:56 am
Thaidog wrote:Does IRIX come with software raid? (Is there a way to configure software raid on IRIX?)
Yes, it's a licensed software for RAID1 and above, RAID0 is not licensed... It's called XLV/XVM...
Thaidog
Unread postby Thaidog » Sat Apr 16, 2005 3:07 am
What do you mean by licensed? Does this software for raid 0 come with IRIX or do you need to buy it?
schleusel
Unread postby schleusel » Sat Apr 16, 2005 4:57 am
Thaidog wrote:What do you mean by licensed? Does this software for raid 0 come with IRIX or do you need to buy it?
both xlv and xvm come with irix but aren't installed by default. xlv is rather obsolete and only there for backward compatibility - i highly recommend xvm these days. Install eoe.sw.xvm (and sysadm_xvm if you want the GUI for it) and get the xvm guide from techpubs:
http://techpubs.sgi.com/library/tpl/cgi ... 7-4003-018
striping (raid0) and concat are free, mirroring (raid1) is only available if you got the plexing license though (thrue for both xlv and xvm)
