ATTENTION FIREFOX/MOZILLA USERS
unixmuseum
Unread postby unixmuseum » Tue Feb 08, 2005 8:10 am
Right off Neowin.net:
FireFox fans across the world, grab the Kleenex!
According to a paper recently published by Eric Johanson of the Shmoo Group, users on most Mozilla-based browsers (Firefox 1.0, Camino .8.5, Mozilla 1.6, etc), Safari 1.2.5, Opera 7.54, Omniweb 5 are victim to a complex International Domain Name [IDN] spoof.
This new attack allows an attacker/phisher to spoof the domain/URLs of businesses. Every recent gecko/khtml based browser implements IDN (which is just about every browser except for Internet Explorer). The Smoo Group have created a proof of concept where the links are directed at "http://www.pаypal.com/", which the browsers punycode handlers render as http://www.xn--pypal-4ve.com.
According to the group there is however an easy to way to detect you're under a spoof attack, cut & paste the url you are accessing into notepad or some other
tool (under OSX, paste into a terminal window) which will allow you to view what character set/pagecode the string is in. You can also view the details of the SSL cert etc.
You can disable IDN support in Mozilla products by setting 'network.enableIDN' to false. There is no known workaround for Opera or Safari. Vendor responses have been varied with VeriSign and Apple failing to respond but Opera believing they have correctly implemented IDN, and will not be making any changes (oops). Mozilla are currently working on finding a good long-term solution. The company provided a clear workaround for disabling IDN temporarily until it can better address the issue.
This latest exploit will provide spammers with a way to trick FireFox, Opera and Safari users into thinking they're on a certain website. Commonly known as Phishing this latest attack by spammers and hackers is frighteningly common.
Update: Many users are reporting the config change in Firefox does not work, currently there is no fix for Firefox.
Neowin's Brandon Goode Contributed to this report
To see if you're vulnerable, take a look here: http://www.shmoo.com/idn/
network.enableIDN set to false works fine for me...
sum][one
Unread postby sum][one » Tue Feb 08, 2005 8:37 am
many thanks.. worked for me as well with Mozilla/windows.. i'll fix that at home on my Sgi as well.
luckly i still use mozilla nd not yet firefox :D
/me owned by mozilla.
:: jean-claude
:: mimgfx dot com
rothers
Re: AtTENTION FIREFOX/MOZILLA USERS
Unread postby rothers » Tue Feb 08, 2005 9:04 am
Unfortunately this only works until you re-start Firefox upon which IDN is re-enabled despite having it set to false in about:config
The real fix is to edit compreg.dat as here:
http://forums.mozillazine.org/viewtopic.php?t=215226
unixmuseum
Re: ATTENTION FIREFOX/MOZILLA USERS
Unread postby unixmuseum » Tue Feb 08, 2005 9:30 am
DARN! Nice catch! Thanks!
makkan77
Unread postby makkan77 » Sat Mar 05, 2005 3:55 am
has this issue been resolved with the 1.0.1 release or is it sort of a feature thats gone bad and will never be "resolved"..
Behold my spermlogo, for it is I: Quick, Ambitious, creative and a tad bit sexually oriented.
[SGI Indigo2 R10K | High Impact | Indigo2 Video for IMPACT with indycam | Irix 6.5.22m]
Hakimoto
Unread postby Hakimoto » Sat Mar 05, 2005 4:39 am
I believe the necessary code has been or will be rewritten to resolve these IDNs differently and make it apparent to the user... if only I hadn't thrown away the link to that article...
grace, elegance and style.
unixmuseum
Unread postby unixmuseum » Sat Mar 05, 2005 8:46 am
makkan77 wrote:has this issue been resolved with the 1.0.1 release or is it sort of a feature thats gone bad and will never be "resolved"..
Yes, it is solved in 1.0.1
makkan77
Unread postby makkan77 » Sat Mar 05, 2005 10:29 am
ahh great..
'cause all those half 'n half fixes seemed well no good..
Unread postby hamei » Sat Mar 05, 2005 11:02 am
makkan77 wrote:ahh great..
Actually, it's not entirely fair to blame the browsers. A big part of the problem is with BIND and crappy dns. If you'd like a discussion of poisoned ip's and the failings of BIND, look for Jonathan deBoyne Pollard's writings on the subject. Phishing *shouldn't* be so easy .....
unixmuseum
Unread postby unixmuseum » Sun Mar 06, 2005 1:15 pm
hamei wrote:Actually, it's not entirely fair to blame the browsers. A big part of the problem is with BIND and crappy dns. If you'd like a discussion of poisoned ip's and the failings of BIND, look for Jonathan deBoyne Pollard's writings on the subject. Phishing *shouldn't* be so easy .....
Maybe, but for once, this doesn't seem to affect IE...
What's amazing with Firefox is the 1984 style of rewriting the history:
"Version X is the most secure web browser in the galaxy" are we told... Until X.01 comes out and then you get a message "Don't use version X, there are so many security holes".
Every time MS releases a security patch, it's a deluge of derogatory comments about how shitty IE is. Yet, when the firefox guys do the same thing, it is presented as a highlight of how great open source is...
Don't get me wrong, firefox has tons of great ideas in it, and obviously far less exploits for now (but for how long, and what kind of damage can skilled programmers do if they have access to a source code?). I find the whole situation rather ironic... It's a competition of marketing spewer, from both sides of the fence...
Now, I am just wondering how much of this "don't use version X" is a way of getting more downloads out of firefox to enforce the "firefox is taking over" propaganda...
Return to “SGI: Security”
