BOINC Client for IRIX/MIPS
dawnview
Unread postby dawnview » Thu Jan 27, 2005 1:00 pm
I know this has been discussed but I have contacted the participants and gotten no response. Does anyone have a current BOINC client running on an Octane? I want to process some units with mine when I am not actively using it.
Thanks in advance! :)
Hakimoto
Unread postby Hakimoto » Thu Jan 27, 2005 3:58 pm
What is BOINC?
grace, elegance and style.
dawnview
Unread postby dawnview » Fri Jan 28, 2005 10:47 am
Sorry, I should have said:
BOINC is a software platform for distributed computing using volunteered computer resources.
I use it to process SETI@home data on my other machines when they are not otherwise occupied.
You can find out more at:
http://boinc.berkeley.edu/intro.php
sincil
Unread postby sincil » Fri Jan 28, 2005 11:07 am
Hi Dawnview,
Firstly apologies for not replying to your PM.
Secondly, I'm not running it any more on my SGI machines because the performance is not so good.
THe binaries that I have are out of date and will not work. I received these from erikDOTtrauschkeATfreenetDOTde.
If you email him, he may be able to supply you with updated binaries.
Regards
Steve
dawnview
thanks
Unread postby dawnview » Tue Feb 01, 2005 8:08 am
Thanks sincil,
What hardware were you running it on? I have an Octane with dual 300s, but I won't bother if its not going to be worth the effort!
I emailed erik but haven't heard back from him.
Regards,
dawnview
sincil
Re: thanks
Unread postby sincil » Tue Feb 01, 2005 8:47 am
dawnview wrote:Thanks sincil,
Regards,
dawnview
Dual 315MHz, 1MB.
If your box is on doing nothing else, you might as well give it something to do.
When I say the performance is not so good.... well.... for dual 315's, performance was good. However when I saw how fast my Pentium 4 box was at crunching units, it kinda extinguished my enthusiasm.
Coupled with the fact that you have to update BOINC and the seti client every now and then, it was just more hassle that it was worth to me.
dawnview
BOINC binary
Unread postby dawnview » Fri Feb 11, 2005 7:14 am
sincil, et al
I heard back from Erik with the latest binary but it does not execute. Does anyone have a list of dependencies for IRIX?
Thanks in advance!
Unread postby nekonoko » Fri Feb 11, 2005 8:20 am
I'm still using the old SETI@Home 3.08 mips4 client here and have no problems getting fresh work units (I just processed one from 24th Dec 2004 for example). No reason to use BOINC until they drop support for the old client which just hasn't happened yet.
dawnview
Unread postby dawnview » Fri Feb 11, 2005 10:33 am
nekonoko,
Thanks, that's an excellent suggestion, I think I will wait and worry about BOINC when they flip the switch!
Regards,
dawnview :oops:
ulenz
Unread postby ulenz » Mon Mar 28, 2005 4:26 am
Take a look there. I've done the installation and it seems to work correctly:
http://setiweb.ssl.berkeley.edu/forum_t ... hp?id=7660
How can we make the Software public available on the seti@home-server ? Is it possible to upload the files to a nekochan-server with permission of the programmers ?
I am using boinc4.58. In order to change the rights for the boinc-/seti-files I used "chmod +x * " in contrast to the installation advice in that thread.
Unread postby nekonoko » Thu Jun 02, 2005 12:12 pm
ulenz wrote:Is it possible to upload the files to a nekochan-server with permission of the programmers ?
Absolutely. In fact, this is one package that could really benefit from a tardist install - the setup process is kind of a pain. It's all detailed in the thread you linked, but requires moving files around plus a special XML file (which specifies an 'anonymous' platform). All of the listed steps could be automated via a tardist.
sgizone
Unread postby sgizone » Fri Jun 03, 2005 2:18 pm
OK call me stupid but I am having no luck getting BOINC/SETI to run on ANY MIPS box. I did get it set up on the 320, but I was hopeing to get it running on the Octane or Onyx.
I downloaded the files indicated on nekochan's front page but when I run bzip2 on it it is an empty file (a 12 Meg empty file) but unusable.
Any help would be appreciated,
Thanks,
James
Unread postby nekonoko » Fri Jun 03, 2005 2:55 pm
Okay, here's a step by step.
1. Download the following files:
SGI_Irix6.5 BOINC V4.58 (2.99 MB) :
http://www.falconfly.de/boinc/boinc_4.5 ... rix6.5.bz2
SGI_Irix6.5 SETI V4.30 (2.59 MB) :
http://www.falconfly.de/boinc/setiathom ... gi_irix6.5
SGI_Irix6.5 app_info.xml (right-click in Browser to 'save as')
http://www.falconfly.de/boinc/app_info.xml
2. Remove bzip2 compression from boinc_4.58_mips-sgi-irix6.5.bz2:
bzip2 -d boinc_4.58_mips-sgi-irix6.5.bz2
3. Set execute bit on setiathome and boinc:
chmod +x boinc_4.58_mips-sgi-irix6.5
chmod +x setiathome_4.30_mips_sgi_irix6.5
4. Create 'boinc' directory:
mkdir boinc
5. Move boinc_4.58_mips-sgi-irix6.5 executable into 'boinc' directory:
mv boinc_4.58_mips-sgi-irix6.5 boinc/boinc
6. Enter boinc directory and run boinc executable:
cd /boinc
./boinc
- The following should occur at this point:
- BOINC will ask for Project URL and Account Key - enter both
- BOINC will then suspend network and computing activity to run benchmark. Interrupt (CTRL-C) while benchmarking to avoid BOINC not finding Berkeley server and automatically detaching project (this is important).
7. Move seti binary and app_info.xml to their final location:
mv ../setiathome_4.30_mips_sgi_irix6.5 projects/setiathome.berkeley.edu/
mv ../app_info.xml projects/setiathome.berkeley.edu/
8. Run BOINC again and let it complete benchmarks. Installation should now be complete.
./boinc
Once everything's up and running, your directory structure should look like this:
[Megumi:~] neko 1% ls -laR boinc/
boinc/:
total 2068
drwxr-xr-x    4 neko     staff        4096 Jun  3 01:56 ./
drwxr-xr-x  116 neko     staff       12288 Jun  3 01:53 ../
-rw-------    1 neko     staff         239 Jun  2 11:58 account_setiweb.ssl.berkeley.edu.xml
-rwxr-xr-x    1 neko     staff     2045476 Jun  2 11:49 boinc*
-rw-r--r--    1 neko     staff        8683 Jun  3 01:56 client_state.xml
-rw-r--r--    1 neko     staff        8683 Jun  3 01:55 client_state_prev.xml
-rw-r--r--    1 neko     staff           0 Jun  2 11:56 lockfile
-rw-r--r--    1 neko     staff       12277 Jun  2 11:58 master.html
drwxr-xr-x    3 neko     staff          37 Jun  2 11:56 projects/
-rw-r--r--    1 neko     staff        2250 Jun  2 23:25 sched_reply_setiweb.ssl.berkeley.edu.xml
-rw-r--r--    1 neko     staff        3004 Jun  2 23:25 sched_request_setiweb.ssl.berkeley.edu.xml
drwxr-xr-x    3 neko     staff          14 Jun  2 11:58 slots/
boinc/projects:
total 8
drwxr-xr-x    3 neko     staff          37 Jun  2 11:56 ./
drwxr-xr-x    4 neko     staff        4096 Jun  3 01:56 ../
drwxr-xr-x    2 neko     staff        4096 Jun  2 23:25 setiweb.ssl.berkeley.edu/
boinc/projects/setiweb.ssl.berkeley.edu:
total 3448
drwxr-xr-x    2 neko     staff        4096 Jun  2 23:25 ./
drwxr-xr-x    3 neko     staff          37 Jun  2 11:56 ../
-rw-------    1 neko     staff      361977 Jun  2 13:32 03dc03ab.22340.16593.523582.253
-rw-r--r--    1 neko     staff        7658 Jun  3 00:38 03dc03ab.22340.16593.523582.253_3_0
-rw-------    1 neko     staff      361965 Jun  2 23:25 03dc03ab.22340.19490.286082.71
-rw-r--r--    1 neko     staff         414 Dec 31 17:46 app_info.xml
-rwxr-xr-x    1 neko     staff     2725300 Jun  2 11:59 setiathome_4.30_mips_sgi_irix6.5*
boinc/slots:
total 4
drwxr-xr-x    3 neko     staff          14 Jun  2 11:58 ./
drwxr-xr-x    2 neko     staff         156 Jun  2 23:26 0/
boinc/slots/0:
total 20
drwxr-xr-x    2 neko     staff         156 Jun  2 23:26 ./
drwxr-xr-x    3 neko     staff          14 Jun  2 11:58 ../
-rw-r--r--    1 neko     staff           0 Jun  2 23:25 boinc_lockfile
-rw-r--r--    1 neko     staff        2809 Jun  2 23:25 init_data.xml
-rw-r--r--    1 neko     staff          99 Jun  2 23:25 result.sah
-rw-r--r--    1 neko     staff          96 Jun  2 23:25 setiathome_4.30_mips_sgi_irix6.5
-rw-r--r--    1 neko     staff        1567 Jun  3 01:56 state.sah
-rw-r--r--    1 neko     staff           0 Jun  2 23:25 stderr.txt
-rw-r--r--    1 neko     staff          95 Jun  2 23:25 work_unit.sah
My 'boinc' binary is a tad smaller since I ran 'strip' on it.
sgizone
Unread postby sgizone » Sat Jun 04, 2005 7:59 am
How can one look at the status of their work units (for loss of a better term) under IRIX? On the 320 I can open the Boinc manager and see what is going on, how can I do this on IRIX? Right now I am getting a "No Schedulers response' but it is requesting more work to get this error. According to the Seti site and my account the machine was sent some work units. Where do I look on the machine to see how many and the status of them.
Thanks,
James
babyrne
Unread postby babyrne » Tue Jun 07, 2005 10:28 pm
Your directory structure didn't turn out like mine.
In your projects directory, you have "setiweb.ssl.berkeley.edu", whereas I have "setiathome.berkeley.edu"
As I understand things, that folder should reflect the URL of the project that it is attaching to, so I'm wondering how your's got a different name?
Not that it matters, your's seems to work, mine keeps throwing client errors. Maybe if it ever gets a work unit without an error I'll get the ssl directory.
Barry
