Rise of the Triad
squeen
Rise of the Triad
Unread postby squeen » Tue May 20, 2003 4:40 am
I just tried Rise of the Triad on an Octane2 under 6.5.19. The binaries at the official site were compiled with the SDL libaries in the /usr/lib32 directory, not the /usr/freeware/lib32 directories so I tried recompiling the source (first with cc then with gcc), with the SHAREWARE flag set to 1 and the SUPERROTT flag set to 0. Both times it seem to compile fine, just a few warnings. I created the ~/.rott directory and copied over the huntbgin .rtc, .rtl and .wad files into it.
Unfortunately when I ran the executable I got (in inverse blue and red text):
Rise of thShareware VersionVersion 1.4 Z_INIT: 8950000 bytes
IN_StartupWnffoundles:ent
LoadScriptFile(/usr/people/queen/.rott/sound.rot), size=1247
LoadScriptFile(/usr/people/queen/.rott/config.rot), size=3210
LoadScriptFile(/usr/people/queen/.rott/battle.rot), size=7010
In SetupWads()
W_InitMultipleFiles()
ÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÉ͵Rise of the Triad Error!ÆÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ͵vS1.0ÆÍ»ÄÄÄÄÄÄÄÄÄÄÄÄÄĺ ºÄÄÄÄÄÄÄÄÄÄÄÄÄĺ ºÄÄÄÄÄÄÄÄÄÄÄÄÄĺ Please run ROTTHELP.EXE forEpisode = 0pful information. ºÄÄÄÄÄÄÄÄÄÄÄÄÄÄÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄÄArea = 1ÄÄÄÄÄÄÄÄÄÄ
Does anyone have any advice?
Unread postby dexter1 » Tue May 20, 2003 6:44 am
hm, it bombs out here as well.
I use the binary and SDL from freeware. I get to exact the same point as you, and this is an O2 running 6.5.19m. the linker should find the SDL libraries, as is the case with my setup:
mech046 /tmp/rott> ldd rott
libSDL-1.2.so.1 => /usr/freeware/lib32/libSDL-1.2.so.1
libpthread.so => /usr/lib32/libpthread.so
libSDL_mixer-1.2.so.1 => /usr/freeware/lib32/libSDL_mixer-1.2.so.1
libc.so.1 => /usr/lib32/libc.so.1
libm.so => /usr/lib32/libm.so
libdl.so => /usr/lib32/libdl.so
libaudio.so => /usr/lib32/libaudio.so
libnas.so.1 => /usr/freeware/lib32/libnas.so.1
libXt.so => /usr/lib32/libXt.so
libX11.so.1 => /usr/lib32/libX11.so.1
libXext.so => /usr/lib32/libXext.so
libaa.so.2 => /usr/freeware/lib32/libaa.so.2
libvorbisfile.so.4 => /usr/freeware/lib32/libvorbisfile.so.4
libvorbis.so.1 => /usr/freeware/lib32/libvorbis.so.1
libogg.so.1 => /usr/freeware/lib32/libogg.so.1
libgen.so => /usr/lib32/libgen.so delay-load
libcurses.so => /usr/lib32/libcurses.so
Maybe it needs a fresh recompile...
vegac
Unread postby vegac » Tue May 20, 2003 7:37 am
Easier way to run RoTT...
setenv LD_LIBRARY_PATH /usr/freeware/lib32
./rott_shareware (or whatever it's called?)
That should run it...
Or how I do it in bash
LD_LIBRARY_PATH=/usr/freeware/lib32 ./rott_registered
squeen
problem solved
Unread postby squeen » Tue May 20, 2003 9:14 am
Thanks, the pre-compiled binary (rott.shareware) works fine after using the environment variable to redirect the library path to the /usr/freeware libs. I didn't know you could do that!
I still wonder why the recompiled version failed, but I'm plenty happy for now.
vegac
Unread postby vegac » Tue May 20, 2003 2:00 pm
Ya I'm not really sure why it would have issues either, but hey, atleast it can be convinced to work, right? :)
necron2600
Re: Rise of the Triad
Unread postby necron2600 » Sun Nov 20, 2016 5:24 pm
Anyone have a copy of this binary.. and source?
The wayback machine does not seem to have a full archive of this site:
https://web.archive.org/web/20050308174 ... bshu/rott/
rott.registered.gz
rott.shareware.gz
sgi_rott_source320x200.tar.gz
Im sure someone has a copy of these files lying around?
Thanks
Unread postby vishnu » Sun Nov 20, 2016 9:29 pm
The unported source code is here: ftp://ftp.3drealms.com/source/rottsource.zip
Unread postby ClassicHasClass » Mon Nov 21, 2016 9:55 am
I've got the SDL source code for the Mac OS X version (which I modified to run windowed). It probably works on IRIX. I'll see about gathering it together if no one else can find the IRIX binaries.
necron2600
Unread postby necron2600 » Fri Aug 04, 2017 9:40 pm
Adding to this thread.. binary I found. (its opensource compiled.. no copyright issues as far as I am aware of)
Rott-compiled-irix.zip
IRIX binary for Rise of The Triad
(799.36 KiB) Downloaded 9 times
Tiny window.. unless you set your X display to be as tiny.
Works on my Octane2... except sound. constant hiss but I have not looked into it.
I had to place my legally purchased ROTT files (4 of them) into ~/.rott/ as well as the same files in ~/.rott/darkwar/ for some reason for it to startup on the first level.
necron2600
Unread postby necron2600 » Fri Aug 04, 2017 9:45 pm
sound+music work great once I set:
export SDL_AUDIODRIVER=AL
necron2600
Unread postby necron2600 » Fri Aug 04, 2017 9:58 pm
A trick to 'double' the size of the screen of rott in IRIX..
run oglsnoop. stretch the oglsnoop window to its largest, then zoom out a few times so the rott window can fit in it.. and then you have a larger game screen. Its a bit better to play now on a 1920x1080 desktop.
