ESP and W32/Sasser-A worm
squeen
Unread postby squeen » Wed May 05, 2004 5:20 am
Not really an IRIX security problem, but it might help to know:
Description
SGI has released an advisory indicating that the W32/Sasser-A worm described in TruSecure Alert 7608 propagates over the same port (5554/tcp) used by the SGI Embedded Support Partner (ESP). The ESP web server is enabled by default on systems running SGI IRIX. As a result, virus detection applications that scan for infections based on port activity may report an infection on IRIX systems running ESP.
Impact
This issue could cause virus detection software and port scanners to incorrectly determine that SGI IRIX systems running ESP are infected by W32/Sasser-A or its variants.
Patches/Software
SGI has released a security advisory at the following FTP link: 20040501-01-I["ftp://patches.sgi.com/support/free/security/advisories/20040501-01-I.asc"]
Hakimoto
Unread postby Hakimoto » Wed May 05, 2004 2:12 pm
Thanks for the info, squeen, for me this is important. It's much appreciated.
grace, elegance and style.
Return to “SGI: Security”
