It is currently Sun May 19, 2013 5:42 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page 1, 2  Next
 Post subject: houdini 6.5 irix
Unread postPosted: Tue Apr 27, 2004 6:21 am
is out :D
r-a-c.de
 Post subject:
Unread postPosted: Tue Apr 27, 2004 7:28 am
you mean Houdini Releae 6.5 for IRIX??... sidefx.com website still talks about Houdini 6.1 ... you have any other links about it?
and also.. voices told me that Sidefx will drop IRIX support since version 7.0 :( .. anyone can confirm that?
EDITED : Found it :) i'll try it later tonight on my octane.. now trying on XP... and found some bugs.. it must be a Gold release btw.. i guess.
:: jean-claude
:: mimgfx dot com
 Post subject:
Unread postPosted: Tue Apr 27, 2004 11:05 am
It's not a gold release, it's still beta. SESI will release new builds weekly, until all major bugs are discovered and squashed. Then it will go Gold, it was the same with 6.1.
 Post subject:
Unread postPosted: Tue Apr 27, 2004 1:40 pm
.. and i found some already :)..
do you also have any news about IRIX support dropping by SideFX?
:: jean-claude
:: mimgfx dot com
 Post subject:
Unread postPosted: Tue Apr 27, 2004 5:19 pm
hello,
for 6.5 look at:
http://sidefx.vislab.usyd.edu.au/cd1_6.5.51
one person said the 'v7 last irix' stuff some time ago but nobody confirmed it.
well informed people also never heard of this. we'll see...
r-a-c.de
 Post subject:
Unread postPosted: Wed Apr 28, 2004 1:24 am
did you successfully installed it?.. its first time that i cant get it installed..
i downloaded the tar.gz file then i have a Tar file and two directories, where inside one directory ther's a 'houdini_install' script. If i run it it popups the usual winterm windows but instead of installing it it tells me that i must run the setup as root (while I am root when running the script).
maybe i really have to login as root instead of doing 'su", even if this sounds strange?
the windows version installed properly instead.. but some bugs makes it crash or close down very often here. :)
:: jean-claude
:: mimgfx dot com
 Post subject:
Unread postPosted: Wed Apr 28, 2004 2:54 pm
i never used the install script.
just extract the houdini.tar.gz from inside the extracted download file to a folder of your choice.
r-a-c.de
 Post subject:
Unread postPosted: Thu Apr 29, 2004 1:00 am
thanks.. i'll give a try later tonight.. how you found it btw? stable enought?
:: jean-claude
:: mimgfx dot com
 Post subject:
Unread postPosted: Sat May 01, 2004 9:18 pm
crappy!
6.5.51 crashes everytime i wanna use open or save dialogs.
6.5.53 even doesn't startup!
quick-checked the new features and if you're happy with 6.1 and don't miss something
special stay with it!
r-a-c.de
 Post subject:
Unread postPosted: Thu Jun 03, 2004 12:35 am
Are there any newer versions for IRIX past 6.5.51? I was planning on posting a note on the front page but version 6.5.83 appears to be Linux/Windows only ...
 Post subject:
Unread postPosted: Thu Jun 03, 2004 12:55 am
damn.. i hope they're just bit late with IRIX release... i wont imagine if houdini has been really dismissed from IRIX :(
:: jean-claude
:: mimgfx dot com
 Post subject:
Unread postPosted: Thu Jun 03, 2004 8:52 am
no, the 6.5.x version are just for testing so the supported versions will diff. sometimes.
try this: http://sidefx.vislab.usyd.edu.au/houdini-6.5.67/
worked fine for me.
r-a-c.de
 Post subject: Re: houdini 6.5 irix
Unread postPosted: Tue Oct 21, 2008 5:46 am
the link is down. Is there anyway I get get the latest version of Houdini apprentice for irix?
Unread postPosted: Thu Oct 23, 2008 1:56 pm
I believe the Irix version was dropped some time ago. I remember checking into that a few years ago.
:O2: :Octane: :1600SW:
Unread postPosted: Mon Nov 24, 2008 3:34 am
I have 6.5.51; the 6.5.67 I downloaded back then seems to be corrupt.
