Choosing Compilers
ruckusman
Choosing Compilers
Unread postby ruckusman » Fri Mar 12, 2004 11:46 pm
Dumb question time,
I would like to compile the package found here
http://www.harrington.com/QuadReadMe.html
as an add on to Gimp-Print
But I have an evaluation version of th MIPS Pro compiler installed that has timed out, so when I try to run the makefile it gives me errors about the licence.
Can someone tell me what I have to do to to get the GCC compiler to execute instead. I'm sure I've done this before but can't for the life of remember how.
Thanks
Glenn
Unread postby foetz » Sat Mar 13, 2004 1:05 am
hello,
just set CC=gcc and CXX=g++
Re: Choosing Compilers
Unread postby hamei » Sun Mar 14, 2004 2:07 am
Are you sure there are actual errors ? I could swear I've read SGI people saying that the eval versions do time out and nag you but they still work anyway.
Altho with SGI's new bottom-feeding habit trying to bleed every little nickel from every potential user, it's possible that that has been changed :-(
ruckusman
Positively negative
Unread postby ruckusman » Sun Mar 14, 2004 7:02 am
Yes unfortunately, it wasn't even a demo licence, it was installed on the machine when I got it and has a dummy password of 0. I did have an Indy some time ago that had a demo licence installed, SGI no longer offers demo/evaluation licences for their compilers, checked yesterday and I can't seem to get the above commands to work, it still defualts to the Mips Pro compiler and says no licence is installed :( If anyone could help out, I'm totally in the dark here, tried compiliing ages ago, but I've lost all of my notes that I had to get me started.
ShadeOfBlue
Unread postby ShadeOfBlue » Sun Mar 14, 2004 8:15 am
If the program you are trying to compile has a configure script, then do this before compiling:
(I'll assume that you are using the tcsh shell and you are running this on a mips4 machine (R5000 and up), otherwise change mips4 to mips3)
setenv CC "gcc"
setenv CFLAGS "-mips4 -mabi=n32 -mtune=mips4 -I/usr/freeware/include -I/usr/local/include"
setenv CXX "g++"
setenv CXXFLAGS "-mips4 -mabi=n32 -mtune=mips4 -I/usr/freeware/include -I/usr/local/include"
setenv CPPFLAGS "-I/usr/freeware/include -I/usr/local/include"
setenv LDFLAGS "-mips4 -L/usr/freeware/lib32"
./configure [plus any options from './configure --help' you might want to specify]
gmake
gmake install [as root]
And that's all! (That is, if the configure script isn't broken...)
If it has a Makefile and no configure script then you'll have to edit it.
Good luck!
Unread postby foetz » Sun Mar 14, 2004 5:24 pm
hello,
i never tried it but i think it's not necessary to declare -I/xxx 2 times...
ShadeOfBlue
Unread postby ShadeOfBlue » Sun Mar 14, 2004 10:32 pm
foetz wrote:i never tried it but i think it's not necessary to declare -I/xxx 2 times...
Yes, that's true, only once should do... but some sonfigure scripts are badly written and they ignore CPPFLAGS...
Don't know if they fixed that yet, so I declared the includes twice... just to make sure ;)
ruckusman
Getting close help please
Unread postby ruckusman » Mon Mar 15, 2004 3:16 am
O.K the about the setting the compile environment worked a treat, editing the makefiles, but...
I had to get the printutil.h file from the gimp-print source and modifiy a few other things and I'm nearly at the end, but I keep getting an error that I can't figure out, it's at the end of this makefile
# Makefile file for QuadToneRIP Raster Source
# Copyright (c) 2003 -- Roy V. Harrington
QUAD_SOURCES = quadraster.c raster.c
QUAD_HEADERS = raster.h
QUAD_OBJECTS = quadraster.o raster.o
QUAD_PROGRAM = quadraster
RASTER_SOURCES = rastertoprinter.c raster.c
RASTER_HEADERS = raster.h xmalloc.c
RASTER_OBJECTS = rastertoprinter.o raster.o
RASTER_PROGRAM = rastertoprinter-quad
RASTER_SCRIPT = quadrastertoprinter
RASTER_LIBRARY = main/libgimpprint.a
CC = gcc
CXX = g++
CXXFLAGS = -mips4 -mabi=n32 -mtune=mips4
CPPFLAGS = -I/usr/freeware/include -I/usr/local/include
CFLAGS = -g -O -I. -DQUADPATH=\"`cups-config --datadir`\" -mips4 -mabi=n32 -mtune=mips4
LDFLAGS = -mips4 -L/usr/freeware/lib32
INSTALL = install -c -m 755
CUPSDATADIR = /usr/freeware/share/cups/
CUPSFILTER = /usr/freeware/lib32/cups/
QUADBINARY = /usr/freeware/bin
all: $(QUAD_PROGRAM) $(RASTER_PROGRAM)
install: $(QUAD_PROGRAM) $(RASTER_PROGRAM) $(RASTER_SCRIPT)
$(INSTALL) $(QUAD_PROGRAM) $(QUADBINARY)
$(INSTALL) $(RASTER_PROGRAM) ${CUPSFILTER}
$(INSTALL) $(RASTER_SCRIPT) ${CUPSFILTER}
clean:
rm -f $(QUAD_OBJECTS) $(RASTER_OBJECTS)
rm -f $(QUAD_PROGRAM) $(RASTER_PROGRAM)
rm -f $(RASTER_LIBRARY)
cd main; make clean
$(QUAD_OBJECTS): $(QUAD_HEADERS)
$(RASTER_OBJECTS): $(RASTER_HEADERS)
$(QUAD_PROGRAM) : $(QUAD_OBJECTS)
cc -g -o $(QUAD_PROGRAM) $(QUAD_OBJECTS)
This line is causing te problems
$(RASTER_PROGRAM) : $(RASTER_OBJECTS) $(RASTER_LIBRARY)
cc -g -o $(RASTER_PROGRAM) $(RASTER_OBJECTS) $(RASTER_LIBRARY) -lcups -lm
$(RASTER_LIBRARY) :
cd main; make
The error I'm getting is
ld32 : FATAL 9: I/O error (-lcups): No such file or directory
collect2: ld returned 32 exit status
***Error code 1 (bu21)
I'm totally lost on this one, if someone can help I'd really appreciate it
Thanks
Glenn
ShadeOfBlue
Re: Getting close help please
Unread postby ShadeOfBlue » Mon Mar 15, 2004 4:23 am
ruckusman wrote:ld32 : FATAL 9: I/O error (-lcups): No such file or directory
The configure script is broken... Try adding "-L/usr/freeware/lib32" (or wherever the libcups library is...) before "-lcups -lm" on the red line.
That should fix the problem...
The other funny thing is, that the configure script ignored your wish to use gcc as the compiler...
Just change every "cc" to "$(CC)" to fix this...
ruckusman
Getting closer
Unread postby ruckusman » Mon Mar 15, 2004 4:59 am
ShadeOfBlue,
There wasn't a configure script with the source, and I'm not experienced enough to write one so I've edited the makefiles instead, the settings you gave me have worked wonderfully and I've just done a make clean and am trying again with the "-L/usr/freeware/lib32 in the makefile with that particular section
Fingers crossed, thanks heaps everyone for you help so far
Glenn
ShadeOfBlue
Re: Getting closer
Unread postby ShadeOfBlue » Mon Mar 15, 2004 10:23 am
ruckusman wrote:There wasn't a configure script with the source, and I'm not experienced enough to write one so I've edited the makefiles instead
I see. Well, the makefile you posted is quite nicely written, with the libraries at the end of the compile line, like they should be (some makefiles have them in the wrong order or at the beginning...), etc.
Nice to hear that. I hope it will work now :)
ruckusman
Thanks
Unread postby ruckusman » Tue Mar 16, 2004 4:36 am
I've got you to thank for the well set out makefile as I copied verbatim the suggestions you gave me in your earlier post. Thaks heaps for your help as I've now had one success and have a better understanding, so hopefully if I can have a go at compiling some more stuff and maybe make a contribution some day.
Glenn
ShadeOfBlue
Re: Thanks
Unread postby ShadeOfBlue » Tue Mar 16, 2004 5:40 am
ruckusman wrote:I've got you to thank for the well set out makefile as I copied verbatim the suggestions you gave me in your earlier post. Thaks heaps for your help as I've now had one success and have a better understanding, so hopefully if I can have a go at compiling some more stuff and maybe make a contribution some day.
You're welcome :)
I'm glad that I was of some help.
Don't hesitate to post on this forum if you need any further help with compiling something, a lot of people here are willing to help out :)
Good luck at compiling things ;)
