Spectre and Meltdown
astouffer
Unread postby astouffer » Thu Jan 11, 2018 11:52 am
For curiosity's sake I just ran the Spectre and Meltdown test script on my 8203-E4A box and here are the results:
Re: Spectre and Meltdown
Unread postby robespierre » Thu Jan 11, 2018 12:05 pm
I'm not intimately familiar with that tool, but from the messages it appears to be simply scanning for known mitigations and not an actual Proof of Concept attack.
Unread postby vishnu » Thu Jan 11, 2018 10:17 pm
From what I understand (admittedly not much), to use spectre you've got to have local access, and to use meltdown, you can do it over a network if you can figure out a way to crack into a box to install the malware. As of two days ago google says they haven't seen anyone attacking anywhere using either. So for the moment I'm not going to worry about it. I am thinking seriously about changing my home LAN's firewall from Intel/Linux to Sparc/Solaris tho... :shock:
Shiunbird
Unread postby Shiunbird » Fri Jan 12, 2018 3:42 am
I'll try on my 9111-285 once I'm back to Europe.
@vishnu: My firewall currently is Dodoid's box. =p I'm not sure whether the Odroid box is affected though. The problem with non-x86 things is the super high energy consumption. Hardware I have laying around, but my power bill is already too high as it is.
My whole setup draws 135W (2 x86 systems, 8 hard drives, a switch, a modem, 2 ARM boxes). If I would go non-x86 (use my POWER5 as a server, for example), I'd go to 500W+. The POWER5 eats 35W on standby!
If you are aware of low power, non-x86, relatively modern stuff, I'd love to hear about.
johnnym
Unread postby johnnym » Fri Jan 12, 2018 8:53 am
Shiunbird wrote:My whole setup draws 135W (2 x86 systems, 8 hard drives, a switch, a modem, 2 ARM boxes). If I would go non-x86 (use my POWER5 as a server, for example), I'd go to 500W+. The POWER5 eats 35W on standby!
Maybe a little off-topic, so I answered in a new thread...
Unread postby ClassicHasClass » Fri Jan 12, 2018 9:08 pm
The POWER6 is not vulnerable to Meltdown.
It _is_ vulnerable to Spectre. It's not clear whether IBM will offer firmware patches for it yet.
source: tested my own system with the PoC
Unread postby uunix » Sat Jan 13, 2018 1:08 am
ClassicHasClass wrote:The POWER6 is not vulnerable to Meltdown.
Hurrah for my POWER5 then.
johnnym
Unread postby johnnym » Sat Jan 13, 2018 3:38 am
Not necessarily: POWER4 (and then most likely also PowerPC 970 and derivatives) and POWER5 make use of out-of-order and speculative execution, whereas POWER6 uses in-order execution.
Unread postby uunix » Sat Jan 13, 2018 5:36 am
Ahh maaaaaan! :x
astouffer
Unread postby astouffer » Sat Jan 13, 2018 9:57 am
Someone was telling me even the later SPARC cpus and even some Alphas did speculative execution. Itanium might be safe :lol:
Unread postby ClassicHasClass » Sat Jan 13, 2018 9:07 pm
Yes. The 970 is definitely vulnerable, so the POWER4 is also almost certainly vulnerable, and if the POWER6 is, then I would be surprised if the POWER5 weren't. Even though the POWER6 is in-order, it still speculates; out-of-order execution only has to do with how instructions are issued.
skywriter
Unread postby skywriter » Wed Jan 31, 2018 6:22 pm
Any performance processor used branch prediction, speculative execution, and out of order execution. Before attacks were based on them they were the best tools to reduce memory latency - the major performance inhibiter in any high performance system.
Assuming google could even detect this, they’re never going to admit it. A vendors first response is always “none of our other customers have this problem”. It’s like “I never had any contact with Russia”, you know how that turned out - EVERYONE had contact with Russia. Lies make the world go round.
:Skywriter:
DECUS Member 368596
Return to “IBM”
