Tezro sound card
Tezro sound card
Unread postby marius_can_15 » Thu Dec 28, 2017 4:06 pm
Hello there.
I've got some vacation an I have some time to play with my Tezro. I haven't been able to make the sound work. The system has 2 sound cards (MAD and RAD). I cannot connect anything in the RAD (fiber optic or DB connector...). How can I set up the system to use the MAD card. I've connected some speakers to the build in card but no luck with the sound.
:Indigo2: :Fuel: :O2: :1600SW: :Indigo2IMP: :Tezro:
Re: Tezro sound card
Unread postby Raion-Fox » Thu Dec 28, 2017 5:54 pm
Hey Marius,
I have a compatible SoundBlaster PCI card that would work in your machine.
PM me if interested.
Unread postby recondas » Mon Jan 01, 2018 1:06 pm
Not to belabor the obvious, but have you looked at the chkconfig setting for soundscheme
chkconfig soundscheme on
Also perhaps a look at the audio panel to check the mute button setting and which audio output is selected as the default.
