Murasaki, my Tezro (Quad 700, 8GB)
Unread postby Raion-Fox » Mon Dec 25, 2017 10:50 pm
So this beautiful Tezro has been with me since shortly before Christmas, courtesy of my man mopar5150. Thank you again John.
Here's the hinv:
4 700 MHZ IP35 Processors
  Processor revision: 2.1. Scache: Size 4 MB Speed 350 Mhz  Tap 0x1c
CPU 1 at Module 001c01/Slot 0/Slice B: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 2 at Module 001c01/Slot 0/Slice C: 700 Mhz MIPS R16000 Processor Chip (enabled)
CPU 3 at Module 001c01/Slot 0/Slice D: 700 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 6144 Mbytes
Memory at Module 001c01/Slot 0: 6144 MB (enabled)
  Bank 4 contains 1024 MB (Premium) DIMMS (disabled)
  Bank 5 contains 1024 MB (Premium) DIMMS (disabled)
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
Graphics board: V12
  PCI Adapter ID (vendor 0x104c, device 0xac28) PCI slot 2
IOC4 firmware revision 83
IP35prom in Module 001c01/Slot n0: Revision 6.172
And yes I'm aware two DIMMs have been disabled. I will need to crack it open and take a look inside soon - I plan to roll that in with some upgrades in the form of a USB, firewire, and another sound card.
Currently, Murasaki is being run through her paces, compiling GCC for a personal project (and to heat my bedroom!)
For those curious, Murasaki's namesake is Japanese. Her name means "Violet" and I got the original idea from a game called Senran Kagura. Good game, if you like beat 'em ups and don't mind fanservicey cute girls. That blue thing is her bear, "bebe-tan" who is... weird. As fuck.
Unlike the real murasaki this one hasn't gone into an uncontrolled rage or refused to do what I tell it. Good murasaki, good!
Irinikus
Re: Murasaki, my Tezro (Quad 700, 8GB)
Unread postby Irinikus » Mon Dec 25, 2017 10:54 pm
Check, I see that you have some disabled RAM in the system, simply type "enableall" in the command monitor in the PROM, then reboot the system and this should enable all of your memory.
Image ... Image
Dans34
Unread postby Dans34 » Tue Dec 26, 2017 2:01 am
out of interest how loud is such a system when compiling ?
:Octane: R12K/400 Octane, 1024MB, 36GB 15K MAX3036NC , MXI
Irinikus
Unread postby Irinikus » Tue Dec 26, 2017 6:12 am
I haven't done any compiling on mine, but when they start to heat up and those fans speed up, they do become rather loud. (Louder than an Octane. :D )
They have a whole lot of fans of different sizes within them and this causes acoustic interference which helps to increases the apparent noise level.
Image ... Image
marshallh
Unread postby marshallh » Tue Dec 26, 2017 12:39 pm
Tezro has a quite a bit of thermal mass, i.e. it takes at least 10-20minutes of sustained work for it to start increasing, but the fans then do start spooling up faster. They never really slow back down either, since there is so much static consumption :)
All fans running full tilt is a scary sound but one I've not been able to cause thru normal usage.
Unread postby Raion-Fox » Tue Dec 26, 2017 12:45 pm
Yeah attempts to compile GCC last night at -j3 (so I had some core time for other tasks left over) barely made it go above idle.
Intuition
Unread postby Intuition » Wed Dec 27, 2017 11:16 am
Niiiiice :)
Image O2 - 300mhz
aka Casey Christopher
