Octane arrived. Advice on small problem.
Re: Octane arrived. Advice on small problem.
Unread postby vishnu » Thu Dec 21, 2017 3:54 pm
guardian452 wrote:You can strip out the sync with some passives. There are fancier "sync separators" available that aren't necessary because the SGI provides separate sync already. Lots of monitors that can't SOG are at least tolerant of the sync signal so long as the H and V sync are provided on the appropriate pins. I had one like this.
Interesting! Just noticed the wikipedia page shows the differences between the Sun and SGI 13W3s, we believe in standards, that's why we have so many of them! :lol:
https://en.wikipedia.org/wiki/DB13W3
Jack Luminous
Unread postby Jack Luminous » Fri Dec 22, 2017 6:54 am
Intuition wrote:
vishnu wrote:I would like to just get an SGI multilink adaptor, Then maybe the 13w3 out to vga would then be converted properly by the multilink adaptor to show the Octane on a 1600sw. Honestly never seen an Octane displayed on an 1600sw.
I've done it and it works. You can also do the same with another device : Dr Bott SGI Saver. You can sometimes find them cheap on ebay.
Unread postby guardian452 » Fri Dec 22, 2017 11:00 am
MLA is not SOG capable but is SOG tolerant. (It doesn't work with a sun cable).
At least the one I owned. There may have been different models or revisions.
Intuition
Unread postby Intuition » Mon Jan 08, 2018 11:03 pm
I’ve fired up the Octane.
It’s run of the mill at the moment, but am getting parts at the moment.
I’ll either win the bid on a dual 400mhz or get one Ian offered me. Whichever price gives way first.
I’m looking at mxe with tram modules as well for good prices.
Since I’m told I can desktop capture on Octane easier than the o2 I’m holding out at buying the personal video options card but I did find two that were not on eBay for better prices.
So I’m considering.
Should be making more tutorials before the end of January.
Image O2 - 300mhz
aka Casey Christopher
JacquesT
Unread postby JacquesT » Tue Jan 09, 2018 11:12 am
What resolution do you intend to run the Octane at?
Unread postby uunix » Tue Jan 09, 2018 11:30 am
JacquesT wrote:What resolution do you intend to run the Octane at?
Cripes JacquesT, I will try and remember your stuff the weekend honest.
JacquesT
Unread postby JacquesT » Tue Jan 09, 2018 12:08 pm
:) NP.
Intuition - I'm not sure the MXE will push anything beyond 1920x1050 / 1600x1200 so just bear this in mind. My SSI tops out with resolutions that generate a pixel clock of <160Mhz. Also, compiling VFO files on MGRAS is a pita!
Intuition
Unread postby Intuition » Tue Jan 09, 2018 2:26 pm
Well. ATM it only has the basic si card.
I was under the impression that the mxe with Tram modules will help with gl texture displays.
I’d mainly run it at 1600 res for the sw1600
But Ian said the little mlink adapters aren’t that great. I just bought an hp that is great for my daily 3d work. Super crisp etc. but I can’t get the vga to work from Octane so I hooked up the old lg that I used to use and it works fine for now.
There are 5 great condition sw1600 in Seattle right now for $100 each or $50 if you bid ebay. It says local pickup only. But I was going to contact the seller and ask if I can send him the sw1600 box I have to ship one to me. It is mint and has all the bits for shipping.
But. This long story only means anything if I can make the Octane display on a sw1600 in the first place.
Image O2 - 300mhz
JacquesT
Unread postby JacquesT » Wed Jan 10, 2018 3:01 am
I have an HP EliteDisplay E241i for my Mac Pro, it simply will not display the image from the Octane properly. Colour is washed out and the image sits halfway across the panel.
I recently bought a Dell 2407wfp which works perfectly with the Octane. There are quite a few of the older panels that will happily do Sync On Green.
Tram will give you textures, without it you'll just get solid faces / wireframe. Also be aware the SI / SE have half the frame buffer memory (13.5mb) of the SSI / SSE (27mb) so are quite limited in what they can output.
Jack Luminous
Unread postby Jack Luminous » Wed Jan 10, 2018 5:11 am
JacquesT wrote:I have an HP EliteDisplay E241i for my Mac Pro, it simply will not display the image from the Octane properly. Colour is washed out and the image sits halfway across the panel.
Picture halfway across the panel, usually it's because the display needs a VFO with certain reduced blanking values. I let Recondas, the expert on those matters explain further. Washed out colours is strange though.
Intuition
Unread postby Intuition » Wed Jan 10, 2018 7:22 am
I bought the Tram modules coincidentally as they come with an MXE card I got off ebay.
https://www.ebay.com/itm/SGI-Octane-MXE ... SwubRXHERB
He had 5 of these at one point. I just ordered one. I will probably buy a multi link because I want to use the sw1600 with it.
Image O2 - 300mhz
JacquesT
Unread postby JacquesT » Wed Jan 10, 2018 8:10 am
Yes I did ask and he tried to get one working but the VFO wouldn't build, even using the mgras script.
Intuition
Unread postby Intuition » Wed Jan 10, 2018 3:01 pm
I've never seen one of these for sale. I mean, amazon seems to have them but they are more expensive than the multi link adapter... also it shows a picture of something that would work with a mac or pc not an SGI because it doesn't have the 13w3 connection side.
Image O2 - 300mhz
Jack Luminous
Unread postby Jack Luminous » Wed Jan 17, 2018 3:16 am
I found mine on ebay for €90 or something sometimes ago. It has no 13W3, only DVI input. I put it between one of the V12 DCD output and the 1600SW. It works better than the multilink I used before. It displays the boot screen properly and switch graphic mode much quicker than the multilink when the X server starts.
Return to “SGI: Discussion”
