hydra 8.7-dev
necron2600
hydra 8.7-dev
Unread postby necron2600 » Fri Nov 10, 2017 1:51 pm
Hydra 8.7-dev GCC compiled! MIPSPro got close but ended up getting a bit more involved.
Requires neko_libssh
I only tested brute forcing 'ssh' .. there is a lot to test with this tool. Oracle, postgresql, mysql support were not compiled in.
Hydra is a parallelized login cracker which supports numerous protocols to attack. It is very fast and flexible, and new modules are easy to add. This tool makes it possible for researchers and security consultants to show how easy it would be to gain unauthorized access to a system remotely.
It supports: Cisco AAA, Cisco auth, Cisco enable, CVS, FTP, HTTP(S)-FORM-GET, HTTP(S)-FORM-POST, HTTP(S)-GET, HTTP(S)-HEAD, HTTP-Proxy, ICQ, IMAP, IRC, LDAP, MS-SQL, MySQL, NNTP, Oracle Listener, Oracle SID, PC-Anywhere, PC-NFS, POP3, PostgreSQL, RDP, Rexec, Rlogin, Rsh, SIP, SMB(NT), SMTP, SMTP Enum, SNMP v1+v2+v3, SOCKS5, SSH (v1 and v2), SSHKEY, Subversion, Teamspeak (TS2), Telnet, VMware-Auth, VNC and XMPP.
The very simple GUI.. xhydra.. is included.
Can this be moved to beta?
Thanks
neko_hydra-8.7_gcc.tardist
neko_hydra 8.7-dev GCC compiled
(1.88 MiB) Downloaded 8 times
Re: hydra 8.7-dev
Unread postby dexter1 » Sat Nov 11, 2017 2:09 am
Done. I'm a bit out of the loop currently. Please poke me if there is more to be transferred
Users browsing this forum: squire and 4 guests
