LDAP authentication
praetor242
LDAP authentication
Unread postby praetor242 » Thu Nov 09, 2017 8:22 am
So I have LDAP authentication setup on my network, but not sure how to get IRIX to use it.
Is there a tutorial somewhere for 6.5.30? Or can someone point me in the right direction?
duck
Re: LDAP authentication
Unread postby duck » Thu Nov 09, 2017 11:22 am
I set it up on my Octane
Things to keep in mind: You will need to have a local slave ldap server (openldap) if you want to use tls, and you cannot use clogin with pam (you're stuck with the ugly xdm login or something third-party).
I suspect changing passwords (EXOP) won't work, but I don't remember much about that, I might just not have bothered.
___(o)=
\____)
praetor242
Unread postby praetor242 » Thu Nov 09, 2017 4:53 pm
Hmm :( That's not ideal. But I saw some posts about that. What about using stunnel?
duck
Unread postby duck » Fri Nov 10, 2017 6:11 am
Sure, that'll work.
___(o)=
\____)
