Total Longshot - watching TV on my O2
praetor242
Unread postby praetor242 » Tue Oct 24, 2017 5:02 pm
So on my main O2, I have the video capture card, and I have ATT UVerse television and the receiver will output to compost video, but SGI's video in application only formats it as SD, and it's an HDTV cable box.
I have MPlayer compiling, and was wondering if I could use video input from MPlayer to watch my ATT cable on my SGI?
Probably a long-shot but figured I'd ask.
jimmer
Re: Total Longshot - watching TV on my O2
Unread postby jimmer » Tue Oct 24, 2017 10:36 pm
If you got a couple of the red/white/yellow RCA outputs on the back of your HDTV box... I'm 99.99% sure they'll be carrying 'regular' SD signals. Just hook up some cables to the O2 and you're set.
J.
Unread postby uunix » Wed Oct 25, 2017 12:24 am
The AV2 (4 BNC Connectors) will only accept SD.
But you could try one of these from your HDMI device...
http://www.ebay.co.uk/itm/Excelvan-1080P-3G-SDI-To-HDMI-Converter-SD-SDI-SDI-HD-SDI-Video-Audio-Adapter-UK/232530458820?hash=item3623e538c4:g:rDAAAOSwHNxZ6brL
I use these myself and they are good, but haven't tried them with the O2 as such. I'll see if I can get something to test it with tomorrow.
Return to “SGI: Video”
