Quake 1 on O2
EmpireAndrew
Quake 1 on O2
Unread postby EmpireAndrew » Sat Oct 21, 2017 5:28 pm
OK, so I finally got an O2 and did a fresh "standard" install of Irix 6.5.22...
I'm super pleased with how zippy it feels, and was excited to try out Nekoware for the first time.
I decided to give Quake1 a go as it seemed like it didn't need any dependencies according to the description, however it turned out it complained about not being able to find libjpeg.so so I installed libjpeg-turbo from Nekoware, which fixed that error.
However it still won't start...
It takes a quick Ctrl-C to catch the error in the Command Shell as it closes the shell when it exits but the error is:
Opening OpenGL driver libGL.so
Couldn't get an RGB, Double-buffered, depth visual
That message loops a half dozen times before it quits.
Any ideas?
Is something missing from my Irix install?
The OpenGL demos with Irix work so I assume OpenGL is fine...
I literally just installed it from NEkoware and copied in pak0.pak, pak1.pak and config.cfg from a PC registered version of Quake.
The O2 is a 300Mhz R12000 with 1GB RAM
Screen is 1280x1024 @ 72 (or 75, I forget) Hz.
Re: Quake 1 on O2
Unread postby ClassicHasClass » Sat Oct 21, 2017 8:54 pm
What does xdpyinfo say about available visuals?
necron2600
Re: Quake 1 on O2
Unread postby necron2600 » Sat Oct 21, 2017 9:35 pm
I spun up my O2 to test this out for EmpireAndrew.. all I get is a black screen.. i can hear things happening and can use (hear) arrows/enter key but all black.. whether running darkplaces-glx or darkplaces-sdl. It may be because I have my O2's resolution set to 1440x900_60 (custom vfo) and 32x32 buffers.... dunno.
I decided to upgrade my O2''s packages to use the very latest beta tardist for neko_quake (aka darkplaces) and its required neko_libjpeg beta package.. since I had success with doing that on an Octane where darkplaces would originally crash quickly in my particular Octane setup. Still just a black screen on my O2.
On a side note:
ftp://ftp.sgi.com/sgi/quake/ (surprised this ftp site still works today! I believe there are copies on nekochan somewhere too)
sgiquake.tgz package/tarball works quite well on my O2 out-of-box. not as 'polished' graphics as darkplaces will give you though but blockier graphics that you may remember from the 1990s.
Note: quake2 on that ftp server also works well in my experiences.
EmpireAndrew
Re: Quake 1 on O2
Unread postby EmpireAndrew » Sun Oct 22, 2017 7:51 am
@ClassicHasClass:
There is a lot of output from that command, I'm not sure what I'm looking for, this is a screenshot of the first part before it lists all the various modes:
EmpireAndrew
Re: Quake 1 on O2
Unread postby EmpireAndrew » Sun Oct 22, 2017 8:03 am
@necron2600:
I downloaded Quake 1 from the SGI FTP and it seems to work perfectly.
I'll try Quake 2 from there next!
pentium
Re: Quake 1 on O2
Unread postby pentium » Thu Oct 26, 2017 6:13 pm
There is a bug in the Darkplaces binary that causes video to not render at all on the O2. I ran into this problem about five years ago and have never seen a way to resolve it.
@EmpireAndrew: How did you get the regular Quake Binary to behave properly? I was having trouble with the mouse leaving the window focus and effects rendering fullscreen when you were in a windowed session.
necron2600
Re: Quake 1 on O2
Unread postby necron2600 » Fri Oct 27, 2017 10:55 pm
Mouse? what mouse? bah! set -mlook. Keyboard play all the way.. old[er] school! ;)
