Octane R12k 2x400MHz, 768MB, MXI + SE, CADduo, MENET, GigE, Serial
japes
Unread postby japes » Tue Oct 17, 2017 11:59 pm
I'm posting a new hinv for an Octane I posted about sometime ago. Lots of swapping around has happened and it's pretty different now.
The plastics are the same Silicon Graphics Octane style in the previous post. The previous post showed a LED lightbar retrofit with blue and white leds, now it sports green/white. The blue/white light bar is in my Octane2 for obvious reasons. It's full of XIO cards with MXI and ESI graphics along with a MENET card. With the card cage full it is perpetually in fastfan mode but it's not the worst thing...
Shoebox is filled with a CADduo card, hacked 3Com GigE card and a SGI dual serial card.
All these cards mean 10 serial ports, 2 graphic desktops, and 7 network interfaces....maybe I should run a dual 1gigE card?
The file /usr/lib/X11/xdm/Xservers.2key is in place of /usr/lib/X11/xdm/Xservers setting the workstation up for two interactive desktop logins.
duo 1# hinv -vm
      PM20400MHZ Board: barcode KXA987     part 030-1476-001 rev  D
            IP30 Board: barcode LDY425     part 030-1467-001 rev  D
             FP1 Board: barcode EDJ746     part 030-0891-003 rev  A
    PWR.SPPLY.SR Board: barcode AAA7151296 part 060-0028-003 rev  A
        XTALKPCI Board: barcode HPC734     part 030-0952-005 rev  D
     PCI_SIO_UFC Board: barcode MNM068     part 030-1657-003 rev  A
        PCI_ENET Board: barcode ECA773     part 030-1155-002 rev  C
            GM20 Board: barcode DZL083     part 030-0957-003 rev  G
           MOT10 Board: barcode HLG722     part 030-1241-002 rev  H
           MENET Board: barcode JHY709     part 030-0873-003 rev  J
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 768 Mbytes
Xbow ASIC: Revision 1.2
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
IOC3/IOC4 serial port: tty7
IOC3/IOC4 serial port: tty8
IOC3/IOC4 serial port: tty9
IOC3/IOC4 serial port: tty10
Graphics board: MXI
Graphics board: ESI
Gigabit Ethernet: tg1, PCI slot 1
Fast Ethernet: ef1, version 1, pci 3
Fast Ethernet: ef2, version 1, pci 0
Fast Ethernet: ef3, version 1, pci 1
Fast Ethernet: ef4, version 1, pci 2
Fast Ethernet: ef5, version 1, pci 3
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 3
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 0
  PCI Adapter ID (vendor 0x10a9, device 0x0003) PCI slot 1
I'm not logged in on the second head so board 1 isn't running the X server, just login screen
        VC3 rev A, CMAP rev E, Heart rev F
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
        Managed (":1.0") 1280x1024
        VC3 rev A, CMAP rev F, Heart rev F
