Set a custom login screen background for xdm
marshallh
Unread postby marshallh » Mon Oct 16, 2017 1:12 pm
It's mentioned in the wiki, though nobody has ever mentioned it working. Even creating Xsetup with exe permissions didn't do anything.
http://nekochan.net/wiki/IRIX_Installat ... gin_screen
My solution:
1. Open /usr/lib/X11/xdm/Xlogin
2. Under the XAUTHORITY line, add your xli:
/usr/nekoware/bin/xli -onroot -quiet <path to your jpg or rgb>
Notice that -quiet MUST be specified or xdm will stick in a login loop and you'll have to recover from serial console.
3. Done
Since this runs before SGI's clogin, it will run regardless of visuallogin being enabled. If this bugs you could add the check:
if /etc/chkconfig visuallogin ; then
necron2600
Re: Set a custom login screen background for xdm
Unread postby necron2600 » Tue Oct 17, 2017 8:19 am
Awesome! Thank you!
def13
Unread postby def13 » Sun Oct 22, 2017 10:23 am
It's a cool custom !
:Octane2: (in fact a 1.5) mono 400 Mhz - 2Go - VPro V8
