FREE (SF Bay Area pickup only): SGI O2, Cobalt Qube 3 + monitors
retro
Unread postby retro » Sat Oct 14, 2017 3:30 pm
I've got a few items to give away, free to whoever is willing to pick them up.
1. SGI O2
IRIS 1# hinv
CPU: MIPS R5000 Processor Chip Revision: 2.1
FPU: MIPS R5000 Floating Point Coprocessor Revision: 1.0
1 180 MHZ IP32 Processor
Main memory size: 128 Mbytes
Secondary unified instruction/data cache size: 512 Kbytes on Processor 0
FLASH PROM version 4.17
On-board serial ports: tty1
On-board serial ports: tty2
CRM graphics installed
Video: MVP unit 0 version 1.4
 with no AV Card or Camera.
Vice: TRE
This has 2x 2GB HDDs; both are root disks, one containing IRIX 6.3 and the other IRIX 6.5. The CD-ROM drive has the "won't close" problem documented on these forums, but should be fixable. I've also got the granite SGI keyboard & mouse to go with it.
2. Sun Cobalt Qube 3
I'm not sure what size disks are in this, but there are 2 of them (one dead - I just booted it and it told me there was a problem with the RAID, but is otherwise functional).
3. Dell (Sony) UltraScan P1110 monitor
This is a great, old-school, and big CRT monitor. Works very well with the O2. 2 VGA inputs, max res 1800x1440 @ 75Hz. (I usually ran it at 1600x1200 @ 85Hz with a PC.)
4. 2x Dell 1907fpc LCD
These are 5:4 1280x1024 LCD panels. 1 VGA & 1 DVI-D input, 4 port USB 2.0 hub. Stand allows for easy rotation.
I'm offering these here first, but will expand out if there's no interest. I'm hoping someone here has a good home for the O2; I know it's not well specced but maybe someone has a use for it in their collection.
EDIT: Forgot one!
5. Sun Ray 170
All-in-one Sun Ray terminal / 17" LCD display. Can be used as a regular VGA display with a PC.
HurricaneJames
Re: FREE (SF Bay Area pickup only): SGI O2, Cobalt Qube 3 + monitors
Unread postby HurricaneJames » Sat Oct 14, 2017 6:41 pm
PM Sent!
retro
Unread postby retro » Sun Oct 15, 2017 6:19 pm
The O2 has been picked up! Everything else is still available.
rem
Unread postby rem » Sat Nov 04, 2017 6:49 pm
If you ever decide to ship, I can use the qube psu (and a spare qube wouldn't be bad ;) ).
ImageImage Image
Image Image Image
Image Image Image Image Image Image Image Image Image Image Image
retro
Unread postby retro » Wed Nov 08, 2017 5:29 pm
The Dell (Sony) UltraScan P1110 monitor has been picked up - all other items are still available.
rem - the Qube is being held for another member right now; if they decide against paying for shipping, I'll PM you to make arrangements.
retro
Unread postby retro » Mon Nov 13, 2017 4:37 pm
The Qube is gone - the Dell displays & Sun Ray are still available for local pickup.
aperezbios
Unread postby aperezbios » Sat Nov 18, 2017 8:50 am
I'll take the Dell 1907fpc LCD's. I live in Campbell-ish. E-mail sent
Users browsing this forum: FoothillsGeek and 0 guests
