Black Lego O2 Case
55cancri
Black Lego O2 Case
Unread postby 55cancri » Wed Sep 27, 2017 9:11 pm
Well,
I had bought some O2 parts, but could not get the housing. So I thought about what to do with them.
I have thought of everything, but my possibilities are very limited because I have no space and no tools to make wooden housing.
Getting all those Bricks was more expensive then I thought - all had to be ordered from the bay. The boards fit exactly, I had to cut a only few stones. Nothing jiggles inside and it is not getting hot.
Irinikus
Re: Black Lego O2 Case
Unread postby Irinikus » Wed Sep 27, 2017 9:15 pm
Very Cool!
Image ... Image
spiroyster
Unread postby spiroyster » Thu Sep 28, 2017 1:53 am
Indeed, very cool, It's like what a Danish Frank LLoyd Wright would do if employed by 1920's SGI :P
How hot is it in there? o.0. Maybe some 'smooth' lego tops to remove visible the trademark lego connectors running across the top surface ... or is that the point? To make it obviously lego-like.
Congrats. :)
Unread postby jan-jaap » Thu Sep 28, 2017 2:26 am
I wonder if you could make a convincing bug logo out of Lego blocks. Transparent, with some LEDs :)
55cancri
Unread postby 55cancri » Thu Sep 28, 2017 3:26 am
Thanks for all the comments :-)
spiroyster wrote:Indeed, very cool, It's like what a Danish Frank LLoyd Wright would do if employed by 1920's SGI :P
The top and bottom are made of two layers of Lego plates. There are just two small holes, up on the left and right of the case. It does not seem to be hot in there, but I also did not use the machine a lot, so I have to probe it further.
Soon, I want to digitize six VHS Tapes. This is may be a good ventilation test ^^
HurricaneJames
Unread postby HurricaneJames » Thu Sep 28, 2017 6:35 am
Nice! Did you make some of the bricks move so the CD drive tray can slide out?
Dodoid
Unread postby Dodoid » Thu Sep 28, 2017 7:10 am
and a small army of Image
55cancri
Unread postby 55cancri » Thu Sep 28, 2017 10:24 am
HurricaneJames wrote:Nice! Did you make some of the bricks move so the CD drive tray can slide out?
Oh, I forgot to mention that it has no CD-ROM drive, but I don't need it.
... and there is also a LED-Strip connected to the CD-ROM-Molex, so the transparent Bricks can shine when machine turned on 8-)
Return to “SGI: Discussion”
