Over the weekend I was able to do some testing on the different rack graphics systems. I will edit and add items as time permits.
I know recondas will get me for not capturing the UV PROM boot
The question of installing a DM3 in a second compute chassis came up but I don't have one of those cards to test with. If somebody has one let me know and I will give it a try.
No animals were harmed during this test but a V10,a numalink cable and my last glass CRT display gave their lives.
I set up and tried the following..
1) Tezro rack system with V12 connected to another rack unit also with a V12.
2) Tezro rack system with V12 connected to an IR4 G-brick.
3) Onyx4 rack system with the GN2 graphics using ATI cards with IRIX.
4) Onyx4 rack system with the GN2 brick and connected to an IR4 G-brick.
5) Origin350 expansion chassis with a V10 installed with no IP module.
Photo of my test area proving how tolerant my wife is.
Test 1) Tezro rack system with V12 connected to another rack unit also with a V12.
Once the two serial numbers were set the same the system works fine and sees both V12s. The interesting part was that they are two separate displays and the mouse will travel between them but I was not able to drag anything from one display to the other. I saw this same behavior with the SG2 brick displays on the Onyx4 test.
Also got several "barrier sync warning" messages during PROM boot.
PROM Boot
001c01-L1>
entering console mode 001c01 CPU0, <CTRL_T> to escape to L1
Starting PROM Boot process
IP35 PROM SGI Version 6.210 built 02:33:51 PM Aug 26, 2004
IP35 PROM SGI Version 6.181 built 04:34:43 PM Mar 19, 2004
Testing/Initializing memory ........Testing/Initializing memory ................
..... DONE
.Copying PROM code to memory ............... DONE
DONE
Discovering local IO ...................... Discovering local IO ...
................... DONE
Discovering NUMAlink connectivity ......... DONE
Found 2 objects (2 hubs, 0 routers) in 7125 usec
Waiting for peers to complete discovery.... DONE
DONE
*** Barrier sync warning: local=4315, NIC 0x6280d947=4305 (promrev mismatch?)
*** Barrier sync warning: local=4305, NIC 0x550615d9=4315 (promrev mismatch?)
*** Barrier sync warning: local=4348, NIC 0x6280d947=4338 (promrev mismatch?)
*** Barrier sync warning: local=4338, NIC 0x550615d9=4348 (promrev mismatch?)
*** Barrier sync warning: local=4823, NIC 0x6280d947=4813 (promrev mismatch?)
*** Barrier sync warning: local=4813, NIC 0x550615d9=4823 (promrev mismatch?)
*** Barrier sync warning: local=4928, NIC 0x6280d947=4918 (promrev mismatch?)
*** Barrier sync warning: local=4918, NIC 0x550615d9=4928 (promrev mismatch?)
Intializing any CPUless nodes.............. DONE
*** Barrier sync warning: local=5089, NIC 0x6280d947=5079 (promrev mismatch?)
*** Barrier sync warning: local=5079, NIC 0x550615d9=5089 (promrev mismatch?)
Checking partitioning information ......... DONE
*** Barrier sync warning: local=5300, NIC 0x6280d947=5290 (promrev mismatch?)
*** Barrier sync warning: local=5290, NIC 0x550615d9=5300 (promrev mismatch?)
INFO: console subchannel changed: 001c02 CPU2
Local slave entering slave loop
INFO: console subchannel changed: 001c02 CPU1
INFO: console subchannel changed: 001c02 CPU0
Local master entering slave loop
INFO: console subchannel changed: 001c02 CPU3
Loading BASEIO prom ....................... DONE
BASEIO PROM Monitor SGI Version 6.181 built 04:34:05 PM Mar 19, 2004 (BE64)
8 CPUs on 2 nodes found.
Graphics diagnostics
Board version 1 - Buzz revision 3B
On board sdram size: 128 Mb
Cas latency: CAS 3
4 banks by sdram module
Device passed diagnostics
Odyssey board #1 found on nasid 1
Cas latency: CAS 3
On-board (IO9) tigon3 1000BaseT interface
Base I/O Ethernet set to /dev/ethernet/tg0
Probing IOC4 ATA adapter 2
IOC4 RevId = 83
Detected Vendor id/Product MATSHITA DVD-ROM SR-8177
Walking SCSI Adapter 0, (pci id 3)
Walking SCSI Adapter 1, (pci id 3)
Initializing PROM Device drivers ..........
Initializing Base I/O Ethernet Interface...Failed. MII Status Register = 0x79
49
Done.
---------------Interface Configuration Summary----------------
ASIC|Revision|MAC Address : 5701|B5|08:00:69:11:de:c9
Link Negotiation|Advertisement : On|<H10 F10 H100 F100 F1000>
Link|Speed|Duplex|Rx/Tx FlowCtrl: Down|10|Half|Off/Off
DONE
IOC4 RevId = 83
49
Done.
DONE
Test 2) Tezro rack system with V12 connected to an IR4 G-brick.
System comes up, ignores the V12 and uses the IR4 for console and booted fine with an O350/IR4 disk. O350/V12 disk panicked. It was neat seeing the Tezro splash screen coming out of the IR4 due to the brick serial number.
Tezro/V12/IR4
Testing/Initializing memory ............... DONE
Discovering local IO ...................... DONE
Local hub NUMAlink is down.
*** Local network link down
DONE
Found 1 objects (1 hubs, 0 routers) in 5896 usec
4 CPUs on 1 nodes found.
IOC4 RevId = 83
1+ Device Vendor Product: SEAGATE ST3300007LC
2- 3- 4- 5- 6- 7- 8- 9- 10- 11- 12- 13- 14- 15- = 1 device(s)
49
Done.
DONE
IRIS console login:
IRIS 1# hinv
4 700 MHZ IP35 Processors
Main memory size: 4096 Mbytes
IOC3/IOC4 serial port: tty3
IOC3/IOC4 serial port: tty4
IOC3/IOC4 serial port: tty5
IOC3/IOC4 serial port: tty6
Graphics board: InfiniteReality4
IRIS 2#
Test 3) Onyx4 rack system with the GN2 graphics using ATI cards with IRIX.
I was finally able to get this system working. The problem I encountered was that the default vertical sync at power up on the ATI cards was 86Hz(determined with a scope). No monitor I had would display this. I tried breaking off the H&V sync pins on a cable to see if it was SOG, but no luck. By using an Extron display converter I was able to see the PROM screen and install IRIX. Once IRIX starts it is 1280x1024 60Hz. I was only able to get one port on each card to display, but I am not very knowledgeable with the IRIX graphics setup. A side note that even if I set the serial numbers to a "P" the splash screen still comes up Ultimate Vision.
Test 4) Onyx4 rack system with the GN2 brick and connected to an IR4 G-brick.
I connected the IR4 G-brick to the Onyx4 UV system and it booted to the GN2 brick and ignored the IR4. The photo doesn't show some of the numalink cables, but they were there for the test. Those cables were not designed to be taken on and off in a test environment.
Test 5) Origin350 expansion chassis with a V10 installed with no IP module.
This setup didn't work because the chassis thinks it is an expansion chassis missing fan #1 (removed to get the V10 in). I Know that there were cpuless IP modules that may allow this to work, but I don't have one to test with. Interestingly I was not able to set the serial to anything but a "M" serial.
