Octane: R12k 250MHz, 640MB, 2xESI
HurricaneJames
Unread postby HurricaneJames » Tue Sep 26, 2017 8:10 pm
Mr Bill helped me with this awesome box when I thought my first Octane was beyond repair. The dual ESI graphics cards are really sweet. For the moment it is still running IRIX 6.5.3m. I think I'll leave it with that so I can compare/contrast older IRIX 6.5 with 6.5.30.
The only thing this box needed was a drive sled and some LEDs in the light bar. I added one of my 3D printed drive sleds, and I'm debating what to do with the light bar. I might swap in more soft white LEDs, like I did with my first box. However, I'm thinking of doing something a bit more interesting.
I think it might be possible to add a strip of small, surface mount RGB leds. Then I could add a small embedded processor to control them and wire them into the box with the serial port. Then I could do all kinds of cool stuff, from a Knight Rider scanner, to an audio analyzer, to just random disco lights. It will probably be December before I try anything like that though.
hinv -vm
      PM10250MHZ Board: barcode HMM245     part 030-1426-001 rev  C
            IP30 Board: barcode HYB462     part 030-0887-005 rev  A
             FP1 Board: barcode EDJ166     part 030-0891-003 rev  A
    PWR.SPPLY.ER Board: barcode AAE9020463 part 060-0035-001 rev  B
           MOT10 Board: barcode HMG698     part 030-1241-002 rev  H
           MOT10 Board: barcode KYA999     part 030-1241-002 rev  K
1 250 MHZ IP30 Processor
Main memory size: 640 Mbytes
IOC3 serial port: tty1
IOC3 serial port: tty2
Graphics board: ESI
Graphics board: ESI
  PCI Adapter ID (vendor 4265, device 5) pci slot 3
glxinfo -v
display: :0.0
server glx vendor string: SGI
server glx version string: 1.2 Irix 6.5
server glx extensions (GLX_):
    EXT_import_context, EXT_visual_info, EXT_visual_rating,
    SGI_make_current_read, SGI_swap_control, SGI_video_sync, SGIX_fbconfig,
    SGIX_pbuffer, SGIX_swap_group.
client glx version 1.1
client glx extensions (GLX_):
OpenGL vendor string: SGI
OpenGL renderer string: IMPACT/1/1/0
OpenGL version string: 1.1 Irix 6.5
OpenGL extensions (GL_):
    EXT_abgr, EXT_blend_color, EXT_blend_logic_op, EXT_blend_minmax,
    EXT_blend_subtract, EXT_convolution, EXT_copy_texture, EXT_histogram,
    EXT_packed_pixels, EXT_polygon_offset, EXT_subtexture, EXT_texture,
    EXT_texture3D, EXT_texture_object, EXT_vertex_array, SGI_color_matrix,
    SGI_color_table, SGI_texture_color_table, SGIS_texture_filter4,
    SGIX_texture_scale_bias.
glu version: 1.2 Irix 6.5
glu extensions (GLU_):
    EXT_abgr, EXT_nurbs_tessellator, EXT_object_space_tess, EXT_packed_pixels,
    EXT_texture, SGI_filter4_parameters.
Visual ID: 20  depth=8  class=PseudoColor
    bufferSize=8 level=0 renderType=ci doubleBuffer=0 stereo=0
    rgba: redSize=0 greenSize=0 blueSize=0 alphaSize=0
    auxBuffers=0 depthSize=24 stencilSize=8
    accum: redSize=0 greenSize=0 blueSize=0 alphaSize=0
    multiSample=0  multiSampleBuffers=0
    Opaque.
Visual ID: 21  depth=8  class=PseudoColor
    auxBuffers=0 depthSize=0 stencilSize=0
    Opaque.
Visual ID: 23  depth=8  class=PseudoColor
    bufferSize=8 level=1 renderType=ci doubleBuffer=0 stereo=0
    Transparent Index: Index=0
Visual ID: 24  depth=8  class=PseudoColor
    Opaque.
Visual ID: 25  depth=12  class=PseudoColor
    bufferSize=12 level=0 renderType=both doubleBuffer=0 stereo=0
    rgba: redSize=12 greenSize=0 blueSize=0 alphaSize=0
    Opaque.
Visual ID: 26  depth=12  class=PseudoColor
    Opaque.
Visual ID: 27  depth=12  class=PseudoColor
    bufferSize=12 level=0 renderType=both doubleBuffer=1 stereo=0
    Opaque.
Visual ID: 28  depth=12  class=PseudoColor
    Opaque.
Visual ID: 29  depth=12  class=TrueColor
    bufferSize=16 level=0 renderType=rgba doubleBuffer=1 stereo=0
    rgba: redSize=4 greenSize=4 blueSize=4 alphaSize=4
    accum: redSize=16 greenSize=16 blueSize=16 alphaSize=16
    Opaque.
Visual ID: 2a  depth=12  class=TrueColor
    Opaque.
Visual ID: 2b  depth=15  class=TrueColor
    rgba: redSize=5 greenSize=5 blueSize=5 alphaSize=1
    Opaque.
Visual ID: 2c  depth=15  class=TrueColor
    Opaque.
Visual ID: 2d  depth=24  class=TrueColor
    bufferSize=32 level=0 renderType=rgba doubleBuffer=0 stereo=0
    rgba: redSize=8 greenSize=8 blueSize=8 alphaSize=8
    Opaque.
Visual ID: 2e  depth=24  class=TrueColor
    Opaque.
Visual ID: 2f  depth=24  class=TrueColor
    bufferSize=36 level=0 renderType=rgba doubleBuffer=0 stereo=0
    rgba: redSize=12 greenSize=12 blueSize=12 alphaSize=0
    Opaque.
Visual ID: 30  depth=24  class=TrueColor
    Opaque.
uname -aR
IRIX64 IRIS 6.5 6.5.3m 01221553 IP30
