Wanted Tezro switch lever
marius_can_15
Unread postby marius_can_15 » Tue Sep 26, 2017 3:35 pm
I need a switch lever for Tezro. The one that I got with my "new" Tezro came broken.
Thanks.
:Indigo2: :Fuel: :O2: :1600SW: :Indigo2IMP: :Tezro:
Re: Wanted Tezro switch lever
Unread postby Raion-Fox » Tue Sep 26, 2017 5:56 pm
Have you tried superglue?
mopar5150
Unread postby mopar5150 » Fri Sep 29, 2017 1:24 pm
I have tried gluing these before with no luck. If you have a heat gun with a small nozzle that will "weld" the two ends together.
:Tezro: :O3x0: :A350:
jwhat
Unread postby jwhat » Tue Nov 07, 2017 11:05 am
I have parts Tezro chassis, PM if you are still looking for this.
Cheers,
jwhat
Return to “Hardware Wanted”
Users browsing this forum: Irinikus and 1 guest
