Origin 3200 Console Access
r1200gsDave
Unread postby r1200gsDave » Thu Sep 21, 2017 9:11 am
I have the Origin 3200 working I think but I cannot get on the OS console. I have read the docs on the L1 controller and have worked with the commands enough to know what the do but I cannot seem figure out how to actually get access to Irix yet.
What is the magick invocation that I need to get logged in? Or even boot the beast?
r1200gsDave
Re: Origin 3200 Console Access
Unread postby r1200gsDave » Thu Sep 21, 2017 11:15 am
when I issue the pwr up command I get these errors. Is this stopping the system? It the front panel says it is powered up, and the fans fire up.
001c04-L1>pwr uALERT: Error initializing the PIMM0 A DS1780, no acknowledge
ALERT: Error initializing the PIMM0 B DS1780, no acknowledge
ALERT: Error configuring PIMM0 A DS1780 power monitoring: no acknowledge
ALERT: Error configuring PIMM0 A temperature monitoring: no acknowledge
ALERT: Error configuring PIMM0 B temperature monitoring: no acknowledge
001c04-L1>
mopar5150
Unread postby mopar5150 » Thu Sep 21, 2017 12:04 pm
The DS1780 is an environment monitoring chip, same chip that is a nuisance in the Fuel systems. You should be able to disable this in the L1 just to get it going. I believe it is "ENV OFF" but check the docs for that system.
:Tezro: :O3x0: :A350:
r1200gsDave
Unread postby r1200gsDave » Thu Sep 21, 2017 12:26 pm
OK now I am excited! <CTRL-D> is the magick!
I entered l1 which prompted me with this:
001c04-L1>l1
L1 command processor engaged, <CTRL-D> to exit.
001c04-L1>
entering console mode 001c04 console, <CTRL_T> to escape to L1
System Maintenance Menu
1) Start System
2) Install System Software
3) Run Diagnostics
4) Recover System
5) Enter Command Monitor
Option? 1
Unread postby recondas » Sun Sep 24, 2017 9:39 am
If your O3200 came with an L2 controller you can connect to the L2 console port and manage and issue the correct brick start-up sequence for the entire system from there. The L2 also has a ethernet port, so you could use Control D or T to access the L1/L2 or system consoles from any system on that side of your firewall that supports telnet.
The L2 is pretty much the swiss-army-knife/must-have-tool for any IP35 rack system. On the odd chance you're not already familiar with the L2, if your O3200 came with an SGI rack they are usually mounted in a track in the roof of the rack chassis.
If you don't have one John/mopar5150 might still have some available.
