Octane: 2xR12k 300MHz, 2048MB, MXE
HurricaneJames
Unread postby HurricaneJames » Fri Sep 15, 2017 9:58 pm
It took a long time, and more money than I originally planned, but I finally managed to get my first Octane running and nicely upgraded to nearly max spec original Octane. I also fixed the lightbar with some soft white LEDs. I think it came out really nice. The scuffs look way worse in the photo than in real life though. Time to break out my plastic model buffing kit and see what I can do with it.
I've got another Octane that Mr Bill sent when I thought this box was dead from bent front plane pins. The problem with that one is that it ran too darned good from the start. Now that this one is fully running I'm going to try to clear some space off the desk and start playing with the other one to see all the awesome stuff Mr Bill sent (dual SI cards, and I have an extra SI card from my first... is triple SI even possible? I don't know, but I'm going to find out :) )
hinv -vm
      PM20300MHZ Board: barcode JJT946     part 030-1356-001 rev  M
            IP30 Board: barcode DRD561     part 030-0887-003 rev  F
    PWR.SPPLY.ER Board: barcode AAE9500348 part 060-0035-002 rev  A
             FP1 Board: barcode EDJ170     part 030-0891-003 rev  A
           MOT20 Board: barcode GXE670     part 030-1240-003 rev  D
2 300 MHZ IP30 Processors
Heart ASIC: Revision D
Main memory size: 2048 Mbytes
Xbow ASIC: Revision 1.2
  CDROM: unit 2 on SCSI controller 1
Graphics board: EMXI
glxinfo -v
display: :0.0
server glx vendor string: SGI
server glx version string: 1.3 Irix 6.5
server glx extensions (GLX_):
    EXT_import_context, EXT_visual_info, EXT_visual_rating,
    SGI_make_current_read, SGI_swap_control, SGI_video_sync, SGIX_fbconfig,
    SGIX_pbuffer, SGIX_swap_group.
client glx version 1.3
client glx extensions (GLX_):
OpenGL vendor string: SGI
OpenGL renderer string: IMPACT/2/2/4
OpenGL version string: 1.1 Irix 6.5
OpenGL extensions (GL_):
    EXT_abgr, EXT_blend_color, EXT_blend_logic_op, EXT_blend_minmax,
    EXT_blend_subtract, EXT_convolution, EXT_copy_texture, EXT_histogram,
    EXT_packed_pixels, EXT_polygon_offset, EXT_subtexture, EXT_texture,
    EXT_texture3D, EXT_texture_object, EXT_vertex_array, SGI_color_matrix,
    SGI_color_table, SGI_texture_color_table, SGIS_texture_filter4,
    SGIS_detail_texture, SGIS_texture_border_clamp, SGIS_texture_select,
    SGIS_texture_lod, SGIX_list_priority, SGIX_pixel_texture,
    SGIX_texture_multi_buffer.
glu version: 1.3 Irix 6.5
glu extensions (GLU_):
    EXT_abgr, EXT_nurbs_tessellator, EXT_object_space_tess, EXT_packed_pixels,
    EXT_texture, SGI_filter4_parameters.
Visual ID: 20  depth=8  class=PseudoColor
    bufferSize=8 level=0 renderType=ci doubleBuffer=0 stereo=0
    rgba: redSize=0 greenSize=0 blueSize=0 alphaSize=0
    auxBuffers=0 depthSize=24 stencilSize=8
    accum: redSize=0 greenSize=0 blueSize=0 alphaSize=0
    multiSample=0  multiSampleBuffers=0
    Opaque.
Visual ID: 21  depth=8  class=PseudoColor
    auxBuffers=0 depthSize=0 stencilSize=0
    Opaque.
Visual ID: 23  depth=8  class=PseudoColor
    bufferSize=8 level=1 renderType=ci doubleBuffer=0 stereo=0
    Transparent Index: Index=0
Visual ID: 24  depth=8  class=PseudoColor
    Opaque.
Visual ID: 25  depth=12  class=PseudoColor
    bufferSize=12 level=0 renderType=both doubleBuffer=0 stereo=0
    rgba: redSize=12 greenSize=0 blueSize=0 alphaSize=0
    Opaque.
Visual ID: 26  depth=12  class=PseudoColor
    Opaque.
Visual ID: 27  depth=12  class=PseudoColor
    bufferSize=12 level=0 renderType=both doubleBuffer=1 stereo=0
    Opaque.
Visual ID: 28  depth=12  class=PseudoColor
    Opaque.
Visual ID: 29  depth=12  class=PseudoColor
    bufferSize=12 level=0 renderType=ci doubleBuffer=1 stereo=1
    Opaque.
Visual ID: 2a  depth=12  class=PseudoColor
    Opaque.
Visual ID: 2b  depth=12  class=TrueColor
    bufferSize=16 level=0 renderType=rgba doubleBuffer=1 stereo=0
    rgba: redSize=4 greenSize=4 blueSize=4 alphaSize=4
    accum: redSize=16 greenSize=16 blueSize=16 alphaSize=16
    Opaque.
Visual ID: 2c  depth=12  class=TrueColor
    Opaque.
Visual ID: 2d  depth=12  class=TrueColor
    bufferSize=16 level=0 renderType=rgba doubleBuffer=1 stereo=1
    Opaque.
Visual ID: 2e  depth=12  class=TrueColor
    Opaque.
Visual ID: 2f  depth=15  class=TrueColor
    rgba: redSize=5 greenSize=5 blueSize=5 alphaSize=1
    Opaque.
Visual ID: 30  depth=15  class=TrueColor
    Opaque.
Visual ID: 31  depth=15  class=TrueColor
    Opaque.
Visual ID: 32  depth=15  class=TrueColor
    Opaque.
Visual ID: 33  depth=24  class=TrueColor
    bufferSize=32 level=0 renderType=rgba doubleBuffer=1 stereo=0
    rgba: redSize=8 greenSize=8 blueSize=8 alphaSize=8
    Opaque.
Visual ID: 34  depth=24  class=TrueColor
    Opaque.
Visual ID: 35  depth=24  class=TrueColor
    bufferSize=32 level=0 renderType=rgba doubleBuffer=0 stereo=0
    Opaque.
Visual ID: 36  depth=24  class=TrueColor
    Opaque.
Visual ID: 37  depth=24  class=TrueColor
    bufferSize=36 level=0 renderType=rgba doubleBuffer=1 stereo=0
    rgba: redSize=12 greenSize=12 blueSize=12 alphaSize=0
    Opaque.
Visual ID: 38  depth=24  class=TrueColor
    Opaque.
Visual ID: 39  depth=24  class=TrueColor
    bufferSize=36 level=0 renderType=rgba doubleBuffer=0 stereo=0
    Opaque.
Visual ID: 3a  depth=24  class=TrueColor
    Opaque.
uname -aR
IRIX64 octane 6.5 6.5.30m 07202013 IP30
scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          COMPAQ  BF0728683C      HPB3
Device is  ready
/dev/scsi/sc1d2l0:  CD-ROM        PIONEER DVD-ROM DVD-304 1.03
ANSI vers 2, ISO ver: 0, ECMA ver: 0; supports:  termiop synch
Device is  not ready
Re: Octane: 2xR12k 300MHz, 2048MB, MXE
Unread postby Trippynet » Sat Sep 16, 2017 8:48 am
Nice, the amended LED bar looks especially cool!
HurricaneJames
Unread postby HurricaneJames » Sat Sep 16, 2017 9:52 am
The LEDs came out amazing. They look bright white in the photo, but they are a much softer white in real life. In person they look exactly the way I remember the originals.
I managed to put the new LEDs in without damaging the original board, but did some of the craziest "please don't touch" layout of my life. These are the best photos I got, and this was before I had to push everything way down. In the end I added a bit of liquid electrical tape, just to the leads, to make sure the wires did not touch anything.
My next project, after inventorying the box Mr Bill sent, will be restoring the plastics. Fortunately, I happened upon some spare broken plastics from an original Octane that I can practice on with different techniques before going to town on either of these boxes. The picture really highlighted the scuffs, but they are very superficial. I think a little buffing and they will all come right out.
Unread postby uunix » Sat Sep 16, 2017 10:25 am
The light bar does look great, something I will have to address with all my Octanes very soon. They all work, but a little flat, I want them to look like a damn disco!
HurricaneJames
Unread postby HurricaneJames » Sat Sep 16, 2017 11:24 am
uunix wrote:The light bar does look great, something I will have to address with all my Octanes very soon. They all work, but a little flat, I want them to look like a damn disco!
There is not a lot of room in there, but probably enough for a bank of small RGB LEDs and a couple of wires leading to an atiny (or similar embedded chip) mounted under the white enclosure. From there you could snake some wires through the case to the serial port and use that port configure blinky-light goodness.
johnnym
Unread postby johnnym » Sat Sep 16, 2017 11:28 am
HurricaneJames wrote:The LEDs came out amazing. They look bright white in the photo, but they are a much softer white in real life. In person they look exactly the way I remember the originals.
Looks great on the picture above. I made a similar modification to the light bars of my two Octanes end of 2016 but used only one LED:
The color on the picture comes out a little bit too yellow compared to reality. Not sure how close this is to the original color. The LEDs emit light upright from the front.
How does yours look when viewed directly from the front?
HurricaneJames
Unread postby HurricaneJames » Sat Sep 16, 2017 7:38 pm
It is possible to see two distinct light sources when viewed exactly from the front, but within 15 degrees or so they combine into a single solid white bar.
johnnym
Unread postby johnnym » Sun Sep 17, 2017 1:50 am
HurricaneJames wrote:It is possible to see two distinct light sources when viewed exactly from the front, but within 15 degrees or so they combine into a single solid white bar.
Thanks for the frontal picture, I think it still looks great. Maybe when you bend the LEDs a little closer to each other, but then the rest of the light bar will get less light, too.
There's this picture of an original light bar from Igor Kromin's website:
I think it comes out a little dark and the light bar is not that well illuminated. Is this really how it originally looked? Well, it might also depend on the used camera.
Irinikus
Unread postby Irinikus » Sun Sep 17, 2017 1:57 am
Why not just use three LED's?
Image ... Image
johnnym
Unread postby johnnym » Sun Sep 17, 2017 7:49 am
Irinikus wrote:Why not just use three LED's?
That could also work well and would make it easier to overlap the beam angle of the LEDs.
Users browsing this forum: devv and 1 guest
