Origin 3200 Powered On!
r1200gsDave
Unread postby r1200gsDave » Fri Sep 15, 2017 4:44 pm
But it looks like I have some errors....
001c04-L1>pwr uALERT: Error initializing the PIMM0 A DS1780, no acknowledge
ALERT: Error initializing the PIMM0 B DS1780, no acknowledge
ALERT: Error configuring PIMM0 A DS1780 power monitoring: no acknowledge
ALERT: Error configuring PIMM0 A temperature monitoring: no acknowledge
ALERT: Error configuring PIMM0 B temperature monitoring: no acknowledge
001c04-L1>env
Environmental monitoring is enabled, but not running (configuration error).
Description State Warning Limits Fault Limits Current
PIMM0 CPU Enabled 10% 1.71/ 2.09 20% 1.52/ 2.28 -nan
PIMM1 CPU Disabled 10% 0.00/ 0.00 20% 0.00/ 0.00 0.00
DIMM Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.51
2.5V Enabled 10% 2.25/ 2.75 20% 2.00/ 3.00 2.51
1.5V Enabled 10% 1.35/ 1.65 20% 1.20/ 1.80 1.49
3.3V aux Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.34
3.3V L1 Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 3.32
5V aux Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 4.94
12V bias Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.19
PIMM0 SRAM Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 12.19
PIMM0 1.5V Enabled 10% 1.35/ 1.65 20% 1.20/ 1.80 12.19
PIMM0 3.3V aux Enabled 10% 2.97/ 3.63 20% 2.64/ 3.96 12.19
PIMM0 5V aux Enabled 10% 4.50/ 5.50 20% 4.00/ 6.00 12.19
PIMM0 12V bias Enabled 10% 10.80/ 13.20 20% 9.60/ 14.40 12.19
PIMM1 SRAM Disabled 10% 0.00/ 0.00 20% 0.00/ 0.00 0.00
PIMM1 1.5V Disabled 10% 1.35/ 1.65 20% 1.20/ 1.80 0.00
PIMM1 3.3V aux Disabled 10% 2.97/ 3.63 20% 2.64/ 3.96 0.00
PIMM1 5V aux Disabled 10% 4.50/ 5.50 20% 4.00/ 6.00 0.00
PIMM1 12V bias Disabled 10% 10.80/ 13.20 20% 9.60/ 14.40 0.00
Description State Warning RPM Current RPM
FAN 0 LEFT Enabled 2160 2475
FAN 1 CENTER Enabled 2160 2475
FAN 2 RIGHT Enabled 2160 2421
Advisory Critical Fault Current
Description State Temp Temp Temp Temp
PIMM0 A Enabled 30C/ 86F 35C/ 95F 40C/104F -4C/ 24F
PIMM0 B Enabled 30C/ 86F 35C/ 95F 40C/104F -4C/ 24F
PIMM1 A Disabled
PIMM1 B Disabled
001c04-L1>cpu
CPU Present Enabled
0 1 1
1 1 1
2 0 0
3 0 0
001c04-L1>istat memory
SYSMEM [0x30003a30] Size: 42696 Avail: 12940
SMLPOOL [0x30003ab0] Size: 8704/ 272 Avail: 29
BIGPOOL [0x30003a74] Size: 16640/1040 Avail: 15
