How do I fix this?! >:(
praetor242
Unread postby praetor242 » Fri Sep 15, 2017 8:42 am
I'm at my wits end trying to fix the characters on my terminal when I ssh into SDF. I've tried several terminals, including urxvt for unicode support, I've tried different fonts, and I really don't want to start porting xfstt for truetype to IRIX. I just want it to look right. Can haz fix?
escimo
Re: How do I fix this?! >:(
Unread postby escimo » Fri Sep 15, 2017 10:48 am
Does this help?
$ stty sane
SNI: PCD-4H (sphinx), PCD-3Msx (cupido), SCENIC Pro C5 (scenic)
SUN: SPARCstation 2 (toosy), Ultra 60 (<noname>), Blade 2000 (betsy)
praetor242
Unread postby praetor242 » Fri Sep 15, 2017 1:11 pm
No. That didn't work. After poking around, it's because IRIX doesn't have a UTF-8 locale, so I'm working through that finding a locale that works on SDF and on IRIX
Unread postby dexter1 » Fri Sep 15, 2017 3:08 pm
This is similar to my tmux port attempts failing because irix doesn't have an utf8 locale included.
A shame really.
praetor242
Unread postby praetor242 » Fri Sep 15, 2017 6:35 pm
Hmm. this is very vexing.
Unread postby Raion-Fox » Fri Sep 15, 2017 6:39 pm
dexter1 wrote:This is similar to my tmux port attempts failing because irix doesn't have an utf8 locale included.
And porting a utf-8 locale from BSD is out of the question I assume?
praetor242
Unread postby praetor242 » Fri Sep 15, 2017 6:40 pm
I wonder what would be involved to port it. I don't know much about locales.
Unread postby vishnu » Fri Sep 15, 2017 8:41 pm
I've never used it but according to the manpage luit should be able to solve this:
If  you are running in a UTF-8 locale but need to access a remote machine that doesn't support UTF-8,
       luit can adapt the remote output to your terminal:
              $ LC_ALL=fr_FR luit ssh legacy-machine
praetor242
Unread postby praetor242 » Fri Sep 15, 2017 8:52 pm
I wonder if you can run luit in reverse. SDF and #! all have en_US.UTF8 set as their default locale.
Unread postby vishnu » Fri Sep 15, 2017 9:20 pm
praetor242 wrote:I wonder if you can run luit in reverse. SDF and #! all have en_US.UTF8 set as their default locale.
Oh sorry, I must have read your original post backward... :roll:
