Octane2 R12k, 400 MHz, 1Gb RAM, V8, 73Gb SCA-2
JohnnyJohnny
Unread postby JohnnyJohnny » Thu Sep 14, 2017 7:32 am
This unit was part of Dodoid's Montreal haul this summer. Also picked up my 1/4 scale Indigo with Odroid XU4 at the same time.
hinv
1 400 MHZ IP30 Processor
Heart ASIC: Revision E
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V8
gfxinfo
   BUZZ version A.1
   PB&J version 1
   128MB memory
      Banks: 4, CAS latency: 3
    Monitor 0 type: PHL -16265
diskpatch
sc0d1l0:  Disk         IBM-ESXSST373454LC    FNB86C  Serial: 3KP1Q89H
uname
IRIX64 sulley 6.5.28m 07010238 IP30
Drowning in a flood of my own interests...and trying to get at least one thing 100% done.
:Octane2: :Indigo2IMP:
duck
Re: Octane2 R12k, 400 MHz, 1Gb RAM, V8, 73Gb SCA-2
Unread postby duck » Thu Sep 14, 2017 7:40 am
Nice!
Also to get the IRIX minor micro version, use
uname -R
JohnnyJohnny
Unread postby JohnnyJohnny » Thu Sep 14, 2017 11:02 am
And a beauty shot - overall the skin is in very good condition, door and spring are intact, it came with the lockbar, and the lights work.
Unread postby jan-jaap » Thu Sep 14, 2017 11:55 pm
Nice!
Otherwise, beware that by placing it on it's side you've blocked the air intake of the graphics side of that Indigo2. That's not going to end well.
JohnnyJohnny
Unread postby JohnnyJohnny » Fri Sep 15, 2017 4:49 am
Picture angle doesn't show that they are actually 1 inch off the floor, sitting on oak blocks so that the fan and GFX vents are clear.
