My first Octane
1byte
My first Octane
Unread postby 1byte » Fri Sep 08, 2017 11:01 am
I got the one from ebay, $200 sight unseen.
My only worry is that the previous owner "confirmed there were 2 cpu's", and I'm unsure how they did this without removing the heatsink and probably damaging the carrier.
Anyhow, the only information that I know of so far is that it is
CMNB015ANF195, contains 2 drive sleds - but maybe no disks? and contains at least 192MB ram.
And it should be delivered by the 18th.
I can at least get in with a serial console, and check things out. I will need a vga adapter...
Now to go update my signature!
:Octane:
Public GPG key: 3FFC 3492 FEE7 C954 63C9 9E6B F1D0 1A90 B4CE 93BD
Irinikus
Re: My first Octane
Unread postby Irinikus » Fri Sep 08, 2017 11:13 am
You can tell whether it's a single or dual CPU by observing the length of the heatsink.
Note that you can't convert a machine to a dual CPU by simply plugging in another single CPU module. The machine only takes one module which is either a single or dual CPU module.
Single CPU
Dual CPU
Image ... Image
Dodoid
Re: My first Octane
Unread postby Dodoid » Sat Sep 09, 2017 6:54 am
If you deal with Octanes often, you can also sometimes tell a dual CPU system by its weight. Mine is certainly heavier than the single CPU ones.
and a small army of Image
1byte
Re: My first Octane
Unread postby 1byte » Sat Sep 09, 2017 9:26 am
I saw a picture of the board, and it's definitely Dual 195MHz.
:Octane:
Irinikus
Re: My first Octane
Unread postby Irinikus » Sat Sep 09, 2017 9:30 am
Thats great to hear! :D
Image ... Image
1byte
Re: My first Octane
Unread postby 1byte » Tue Sep 19, 2017 3:29 pm
Got the Octane in today. Still looking for a monitor option - need to source adapter, will power on with serial interface soon.
No disk drives, but TWO drive sleds!. BUT I have a 4 disk SCSI Sun external drive enclosure just sitting full of barracuda drives which I might steal one.
The top screw to pull out the graphics board is STUCK and STRIPPED! That's gonna take some repair.
Something seems to have spilled, leaked, into the bottom of the housing on the logic board side. The CPU board looks dusty but pristine. Will keep you posted.
:Octane:
Re: My first Octane
Unread postby Raion-Fox » Tue Sep 19, 2017 5:55 pm
1byte wrote:Got the Octane in today. Still looking for a monitor option - need to source adapter, will power on with serial interface soon.
You can use a screw extractor to get that top screw out. The drive carriers are cheap if it's not a VPro one.
Dodoid
Re: My first Octane
Unread postby Dodoid » Wed Sep 20, 2017 9:30 am
Hmm... picture? I would consider dremeling the top and then removing it with a flathead, but you may damage the plastic "handle" around the screw.
duck
Re: My first Octane
Unread postby duck » Wed Sep 20, 2017 12:49 pm
Be careful with the disk spud trays, they can be fragile. I had one shatter...
___(o)=
\____)
1byte
Re: My first Octane
Unread postby 1byte » Wed Sep 20, 2017 2:05 pm
Dodoid wrote:Hmm... picture? I would consider dremeling the top and then removing it with a flathead, but you may damage the plastic "handle" around the screw.
I'm not sure it needs to be that drastic. Just some pliers and force is all that's really needed. I assume it is bound on the spring. I'll get it out soon!
I just moved into a new place so I don't really have a desk setup yet, but that will also happen soon!
:Octane:
mopar5150
Re: My first Octane
Unread postby mopar5150 » Thu Sep 21, 2017 11:57 am
I wouldn't pull the graphics board unless you need to. Get it tested first. I can send you a bootable drive and graphics cable cheap to get you going.
What graphics do you have?
:Tezro: :O3x0: :A350:
1byte
Re: My first Octane
Unread postby 1byte » Thu Sep 21, 2017 1:13 pm
mopar5150 wrote:I wouldn't pull the graphics board unless you need to. Get it tested first. I can send you a bootable drive and graphics cable cheap to get you going.
Normally I would agree, and it's probably fine, but I wanted to check that pesky rust/leaked weird spot to see if it had damage on the XIO side. I have... some kind of graphics, based on look of the rear panel alone, its either SI or MXI.
I'd love a bootable drive and graphics cable! I was going to try a netboot it when I get my network setup in my new place.
:Octane:
mopar5150
Re: My first Octane
Unread postby mopar5150 » Fri Sep 22, 2017 12:26 pm
Cool,
PM me your shipping address. :)
1byte
Re: My first Octane
Unread postby 1byte » Thu Feb 22, 2018 2:39 pm
Update Feb 2018:
New Power supply. System powers on.
All greed lights on the front plane. No lights on the front bar.
Motherboard gets power at least, as the optical audio lights up.
I hooked up a monitor with an adapter I bought and didn't get anything at all. I haven't done enough research to see what happens when a non SoG monitor is attached, but I didn't get anything at all.
My shiny new null modem cable came in, which is male-female... and that's where my fun stopped for the day. I'll have to wait for the other new female-female cable to come in, hopefully on Monday.
I have three shiny new 36Gb drives to install, and then the fun of selecting an operating system. Still planning on porting FreeBSD in my spare time.
Edit: Drives don't seem to be spinning up. I should probably just disassemble the whole thing and clean it.
:Octane:
Re: My first Octane
Unread postby vishnu » Thu Feb 22, 2018 7:42 pm
1byte wrote:Edit: Drives don't seem to be spinning up. I should probably just disassemble the whole thing and clean it.
Except for the front panel lights you've got quite a few warning flags popping up, that's with mopar's bootable drive and two others? Are the SCSI terminations set right?
