"Intergraph ZX10" problem with AGP Pro / Wildcat 7110
MrWeedster
Unread postby MrWeedster » Thu Sep 07, 2017 8:07 am
Hi.
I have some sort of Franken-ZX10 built on base of a Tyan Thunder 2500 (s1867), which is the board of the intergraphs. I also flashed the SGI Bios on it, which is running great.
Now i wanted to add graphics, and bought a Wildcat 7110 AGP Pro.
Got the card, dropped it in: No output on the monitor, but a BIOS beep, that the GFX is not working (AMI BIOS: 1 long, 2 short beeps). Ok, maybe the card is broken. Contactet the seller: He got another one which he would test and send to me.
I got the "new" and tested card today: Same error. Since this is my only machine with an AGP Pro port (except the prism, but i think that wont work) i dont know what to do next.
Now my question is if its maybe the matter that the AGP Pro port doesnt provide enough current to get a dual GPU card running.
Besides this i have no clue what could be wrong.
Do you have any idea?
GL1zdA
Re: "Intergraph ZX10" problem with AGP Pro / Wildcat 7110
Unread postby GL1zdA » Thu Sep 07, 2017 9:08 am
The Wildcat4 7110 is AGP Pro 50 so it should get enough power from the board. But I'm not sure the board can supply the correct voltage. I think the Wildcat4 might need 1.5V and the board supplies 3.3V.
Shiunbird
Unread postby Shiunbird » Thu Sep 07, 2017 9:13 am
MrWeedster wrote:Now my question is if its maybe the matter that the AGP Pro port doesnt provide enough current to get a dual GPU card running.
System requirements, after a bit of Googling, mention 50 W of required power and AGP 8x.
https://www.rakuten.com/prod/3dlabs-wildcat4-7110-graphics-card-256mb/10336809.html
https://en.wikipedia.org/wiki/Accelerated_Graphics_Port#Power_consumption
The limits look tight indeed.
SiliconClassics
Unread postby SiliconClassics » Thu Sep 14, 2017 10:50 am
This might not be a welcome suggestion but I'd recommend another model of Wildcat. I used a 7110 in a Dell P4 workstation for a while and it eventually broke, giving similar symptoms to the ones you've described: blank screen and BIOS error beeps on boot. Not a very reliable board.
The ZX10 systems originally came with 4000-series Wildcat cards (4110 & 4210) so a 4000/5000 model would be more period correct and probably more robust. They're not hard to find on eBay.
Hakimoto
Unread postby Hakimoto » Tue Nov 14, 2017 9:10 am
I second what SiliconClassics says. IIRC I ran mine with a 5xxx and it was rock solid.
grace, elegance and style.
