How frequently you use your SGI (in 2017)?
How often you use your main SGI workstation?
Poll ended at Wed Dec 27, 2017 11:44 am
Daily for your work.
4
8%
Daily at home.
9
18%
Weekly.
14
27%
Monthly.
8
16%
Few times per year.
10
20%
Have not started it this year.
6
12%
Total votes: 51
jirka
Re: How frequently you use your SGI (in 2017)?
Unread postby jirka » Sat Nov 04, 2017 1:55 am
escimo wrote:
jirka wrote:... and my R3k Indigo cannot play mp3 files).
... Something really went wrong with your configuration, I suppose. ;)
The configuration is OK, I think. But I'm not able to compile the mpg123 for the IRIX 5.3 at the moment (and I am not able to find one which works on the R3k Indigo...).
Unread postby dexter1 » Sat Nov 04, 2017 4:23 pm
jirka wrote:The configuration is OK, I think. But I'm not able to compile the mpg123 for the IRIX 5.3 at the moment (and I am not able to find one which works on the R3k Indigo...).
From geektechnique.org :
mpg123-irix5.3-mips1-static.bin
(224.27 KiB) Downloaded 12 times
Which is the same binary from Marcus' old site ftp.mayn.de
jirka
Unread postby jirka » Sun Nov 05, 2017 2:45 am
dexter1 wrote: From geektechnique.org : mpg123-irix5.3-mips1-static.bin
Thank you very much! It works perfectly. The "gr_top" say that the mpg123 uses between 71%-94% cpu but the sound is great.
mapesdhs
Unread postby mapesdhs » Wed Nov 08, 2017 4:56 am
jirka wrote:Thank you very much! It works perfectly. The "gr_top" say that the mpg123 uses between 71%-94% cpu but the sound is great.
IRIS Indigo was always well regarded for its good sound quality.
Ian.
Dodoid
Unread postby Dodoid » Wed Nov 08, 2017 11:57 am
The Octane also sounds pretty good. Not sure what hardware's in there, but it's great. I often use mine to play music when I'm working downstairs.
and a small army of Image
Unread postby Trippynet » Wed Nov 08, 2017 12:18 pm
And interestingly, I've always been impressed with the sound quality from my Indigo2. Always thought my music sounds better from it than from my PC - of course the PC does have pretty bog-standard onboard audio...
Return to “SGI: Discussion”
