Sun gdm5410 Service port
Unread postby Dalplex » Thu Aug 24, 2017 1:26 pm
Hi, this is not a SGI monitor but may be sharing some knowledge.
Basically, I can not find any place to hook up the cable using the Windas software to adjust the G2 voltage, to correct the over bright issue, as usually available on similar monitor, for example, Dell P1110 and Sony FW900.
The only way I am thinking about is to remove the blue colour lid at the back but it seems like a mission impossible as there is no screw at anywhere.
Any experience on detachng this lid, so the service port can be accessed will be greatly appreciated.
