Aezora - first SGI machine (Octane, 2xR10K 250 MHz, 1 GB RAM, SE)
LarBob
Unread postby LarBob » Wed Aug 23, 2017 5:12 pm
After replacing the system board, power supply, and frontplane as well as figuring out how to network install IRIX from a debian vm, I finally have a working Octane.
hinv:
      PM20250MHZ Board: barcode HPG180     part 030-1286-002 rev  C
            IP30 Board: barcode EAN542     part 030-0887-005 rev  B
    PWR.SPPLY.ER Board: barcode AAE8420002 part 060-0035-001 rev  B
             FP1 Board: barcode JLV144     part 030-0891-003 rev  E
           MOT10 Board: barcode GTM456     part 030-1241-002 rev  F
2 250 MHZ IP30 Processors
Heart ASIC: Revision D
Main memory size: 1024 Mbytes
Xbow ASIC: Revision 1.3
Graphics board: ESI
gfxinfo:
   HQ rev B, GE12 rev A, RE4 rev C, PP1 rev E,
   VC3 rev A, CMAP rev E, Heart rev D
   21" monitor (id 0xb)
    Video Format Flags:  (none)
    Sync Disabled
    Using Gamma Map 0
I am currently just using nekodeps.pl --install for packages as the scripts it generates seem to have 404 errors and nekopkg doesn't work due to an error with an ldap library. I put fsn on the machine and it was so cool to see it running realtime on a machine I own. :lol:
Dodoid
Re: Aezora - first SGI machine (Octane, 2xR10K 250 MHz, 1 GB RAM, SE)
Unread postby Dodoid » Wed Aug 23, 2017 5:27 pm
Nice! Glad you finally got an Octane. A lot of the Nekoware package managers have some problems related to servers going down, but ehh, it works if you point it at the main Nekochan packages. It's slow though.
and a small army of Image
LarBob
Unread postby LarBob » Wed Aug 23, 2017 5:57 pm
Dodoid wrote:Nice! Glad you finally got an Octane. A lot of the Nekoware package managers have some problems related to servers going down, but ehh, it works if you point it at the main Nekochan packages. It's slow though.
Thanks! Yeah, it seems to be doing this:
--2017-08-23 19:55:29--  http://nekochan.net/nekoware/cu
Resolving nekochan.net... 64.81.247.28
Connecting to nekochan.net|64.81.247.28|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2017-08-23 19:55:30 ERROR 404: Not Found.
edit: actually, I switched it to ftp://ftp.nekoware.de/ and it's working fine now. And I'm fine with it being slow. :P
Krokodil
Unread postby Krokodil » Thu Aug 24, 2017 8:27 pm
Welcome to Octane owners club. :)
Alphaserver DS10 - 466MHZ
Sun Ultra 5 - 440MHZ.
LarBob
Unread postby LarBob » Fri Aug 25, 2017 12:51 pm
Krokodil wrote:Welcome to Octane owners club. :)
Thanks! :P
I'm trying to think of some fun stuff to do, I might try to install BSD on another drive soon or something.
Unread postby uunix » Fri Aug 25, 2017 1:15 pm
Sounds like you have been on a mission to get there, but the Octane really is a fine machine. Though like most SGI, very fickle in it's love for you.
LarBob
Unread postby LarBob » Sat Aug 26, 2017 8:21 am
uunix wrote:Sounds like you have been on a mission to get there, but the Octane really is a fine machine. Though like most SGI, very fickle in it's love for you.
Yeah, I really love the design of the Octane. A lot of work was definitely put in to the design. It's probably the coolest machine I own.
Unread postby vishnu » Sun Aug 27, 2017 3:37 pm
Glad you finally got it going, that's a top notch effort on your part! :mrgreen:
JacquesT
Unread postby JacquesT » Sun Nov 26, 2017 1:13 pm
Glad you got it working in the end. I just rejoined the Octane club, almost exactly the same spec but with less ram. Just waiting for for my 13w3-db15 adapter. Enjoy!
