(partialy solved) Octane + Irix 6.5.26 becoming slow
def13
Unread postby def13 » Tue Aug 22, 2017 9:56 am
My Octane (O1.5 - mono 400Mhz - Ram 2Go + V8 + Irix 6.5.26) became subitly slow at start up after I've solve a network connexion problem between this station and my Mac.
I use the HOW TO : IRIX Installation and Customization to solve my problem.
(my ipadresse) IRIS.home.local IRIS
no more ipadress
#$ROUTE $QUIET add net default (my route adress)
I don't do : "Move $HOME for user root and change the default shell"
After login, the display time of the desktop icons has tripled. It takes about 10s to open and display a simple Unix shell window and it's the same for the Icon Catalog ... all actions in the system are slow. And the only software witch doesn't open is Photoshop (Edit : now, after 30' without touching the workstation, Photoshop works !?!?).
It's the same with other users accounts except that Photoshop opens and works perfectly.
After a quicklook in the Process Manager, I found something sounds strange for me :
4 "biod" process - same date/time
2 "eventmond" ...
5 "nfsd" ...
2 "soundscheme" - with more than 2 minutes between them
2 "tfxd" - with more than 2 minutes between them
2 "xdm" - with more than 2 minutes between them
I'm sure I do something wrong and I hope somebody could help me to solve this problem.
:Octane2: (in fact a 1.5) mono 400 Mhz - 2Go - VPro V8
Re: Octane + Irix 6.5.26 becoming slow
Unread postby josehill » Tue Aug 22, 2017 10:17 am
90%+ of the time, this is due to DNS issues. Search nekochan.net for "resolv.conf" to get some ideas.
Most of the rest of the time, it is due to something looking for resources on the previous owner's network, like an NFS share. Take a look at the /etc/fstab file and verify that there are no entries for machines that are not accessible. Also check that none of the desktop icons are aliases that point to resources on the previous owner's network.
def13
Unread postby def13 » Tue Aug 22, 2017 10:39 am
Hello Josehill, thanks for your reply :-)
1- In the "resolv.conf" file I've got :
domain home.local
nameserver (my web-box/router ip-adresse)
2- In the "fstab" file I've got :
/dev/root / xfs rw,raw=/dev/rroot 0 0
3- fter your reply, I've removed from the desktop the alias of my Mac's shared folder.
Unread postby foetz » Tue Aug 22, 2017 11:09 am
also check the nsswitch.conf and make sure everything has "local" first. unless of course you do actually have a network service for the entry
def13
Unread postby def13 » Tue Aug 22, 2017 12:12 pm
Thanks for your reply Foetz.
Here is my nsswitch.conf :
automount(dynamic):   nis(nis_enumerate_key)
#bootparams:      files nis
capability:         files nis
clearance:         files nis
ethers:         files nis
group:         files nis
hosts:         files dns files
ipnodes:         files
mac:            files nis
mail(null_extend_key): ndbm(file=/etc/aliases) nis
netgroup:         nis
#netid.byname:      nis
networks:         files nis
passwd:         files(compat) [notfound=return] nis
protocols:         nis [success=return] files
rpc:            files nis
services:         files nis
shadow(mode=0700):   files
#ypservers:      nis
jlimits:         mdbm nis
Unread postby josehill » Tue Aug 22, 2017 3:05 pm
Try adding this line to /etc/resolv.conf :
hostresorder local dns
You might also try removing the "domain home.local" line, but that's probably not the problem.
The resolv.conf and nsswitch.conf files are both intended to configure DNS. resolv.conf is the "old way," while nsswitch.conf is the "modern way." FWIW, it's probably better to use the nsswitch.conf way, since many newer non-SGI Unix systems use it, but I've never had a problem using the old resolv.conf file, which IIRC takes precedence over nsswitch.conf when both are present.
Unread postby recondas » Tue Aug 22, 2017 3:23 pm
def13 wrote:2 "eventmond" ...
Try running "chkconfig esp off" and reboot.
def13
Unread postby def13 » Wed Aug 23, 2017 3:45 am
Thanks a lot for your help :-)
After a short night, I remembered I have turned ON NIS ... So I've turned it OFF, restarted the workstation and everything works well again ! Except I can't access to the shared folder of my Mac ... :-(
With NIS, I can access to shared folder on my Mac.
Without NIS, I view the shared folder of the Mac but can't accessed to it.
In the two conditions, Mac can access to the shared folder of the SGI.
(^_^'!)
Users browsing this forum: foetz and 1 guest
