Indigo2, R10k 195MHz, 160Mb RAM, High Impact w/ TRAM, 146Gb SCA
JohnnyJohnny
Unread postby JohnnyJohnny » Thu Aug 17, 2017 11:58 am
hinv
1 195 MHZ IP28 Processor
Main memory size: 160 Mbytes
On-board serial ports: 2
Graphics board: High Impact/TRAM option card
EISA bus: adapter 0
gfxinfo
   Managed (":0.0") 1600x1200
   Product ID 0x0, 1 GE, 1 RE, 4 TRAMs
   VC3 rev A, CMAP rev DMC rev D
   21" monitor (id 0xb)
    Video Output: 1600 pixels, 1200 lines, 57.03Hz (1600x1200_57)
diskpatch
sc0d1l0:  Disk         SEAGATE ST3146707LC     0003  Serial: 3KS090B0
uname
IRIX64 bottlecap 6.5 11051732 IP28
Found a vintage audio repair shop right around the corner from my house who repaired my PSU for CA$120. The technician replaced the capacitors, cleaned it out, re-soldered some connections, and chemically cleaned the wiring for the drives. He mentioned that there was signs that the drive wiring was getting really hot, so I'll have to keep an eye on it.
With the PSU working, I could now boot the system and install IRIX 6.5.2m onto the new HHD. My external HP CD-ROM worked just fine, which I was surprised about since I've been having lots of problems with it on my Indy.
Just need to bump up the RAM to 394Mb, then I'll be happy with it.
Drowning in a flood of my own interests...and trying to get at least one thing 100% done.
:Octane2: :Indigo2IMP:
Re: Indigo2, R10k 195MHz, 160Mb RAM, High Impact w/ TRAM, 146Gb SCA
Unread postby dexter1 » Thu Aug 17, 2017 1:54 pm
Give that repairman an extra can of beer, sounds like he deserved it!
A 100 mbit card would be a nice addition, but having 146GB inside is very adequate.
