vitetris 0.57 Irix mips4 (gcc)
Unread postby necron2600 » Wed Aug 16, 2017 3:31 pm
vitetris. Can be in color or mono.. as well as pure vt100 term display. Nothing fancy.. but if your a command-line junky who uses vi and sc.. this is for you.
vitetris is a terminal-based Tetris clone by Victor Nilsson. Gameplay is much like the early Tetris games by Nintendo. Features include:
Configurable keys
Highscore table
Two-player mode with garbage
Network play
Joystick (gamepad) support on Linux or with Allegro
It has been tested on Linux, NetBSD and a few other Unix-like systems, and ported to Windows and DOS. Library dependencies are minimal (only libc is required), and many features can be disabled at compile-time.
CFLAGS=-O3 -mabi=n32 -I/usr/nekoware/include -I/usr/include -I/usr/nekoware/include/ncurses
./configure --disable-joystick --disable-network --disable-2player --disable-pctimer
After configure, modify config.h to add
#include <sys/time.h>
or else a struct timeval error occurs during compile.
vitetris mips4/gcc
(170 KiB) Downloaded 9 times
Users browsing this forum: jirka and 1 guest
