does anyone happen to have a picture of the original packings?
Y888099
Unread postby Y888099 » Sat Aug 12, 2017 4:31 am
does anyone happen to have a picture of the original packings used by SGI machines to sell their machines?
I am interested ( curious anyway ) in what was written out of the box, I am interested in what was used to make the shipping safe.
I have recently seen a software made by SGI which allows you to design a packaging based on the mechanical draw of the object. Unfortunately it's node locked onto an old Indigo2 machine, but it's interesting because it generate CAM-ish-like (for sure a proprietary format) file good to design extruded on polystyrene.
To remap it into nowadays technology, it's like if you design something on SolidWorks (I don't know the equivalent software on SGI), you create a CAM file, you import into extrude generator (custom application?), thus you have a cutter machine that produces the packaging's material, and you just have to assemble the whole into the box.
Easy life :D
Shiunbird
Re: does anyone happen to have a picture of the original packings?
Unread postby Shiunbird » Mon Aug 14, 2017 1:56 am
SiliconClassics' video shows one, albeit briefly, at 2:55.
https://www.youtube.com/watch?v=Qk_JjfeChQA
edit: add time.
SiliconClassics
Unread postby SiliconClassics » Mon Aug 14, 2017 2:46 am
I also posted a photo of the Indy box contents here.
Y888099
Unread postby Y888099 » Mon Aug 14, 2017 8:09 am
ohhhh, super thanks, guys :D
looking at Perfectly Designed Polystyrene Packaging Solutions =P
Return to “SGI: Discussion”
