Burnt AAUI on PM6100??
zahal
Unread postby zahal » Fri Aug 11, 2017 8:57 pm
Hello,
I'm trying to build a hotrod PowerMacintosh 6100. So far it's got 264MB RAM, a 36GB 15k SCSI drive, a Pioneer DVR105, a 2MB HPV card (upgradeable to 4MB), and a Sonnet G3 running at 247MHz. The hard disk gets hot fast, so I will probably replace it with a 7.2K drive, or a smaller (2.5inch) 10k drive.
Sadly, the onboard AAUI ethernet port seems to be acting up. With a Farallon transceiver the network is not detected (a red X over the ethernet extension at startup). With an Apple AAUI to 4RJ45 hub, the ethernet port seems to be up (I can get the MAC address on TCP/IP control panel) and Appletalk does not complain if I select the Ethernet port. BUT, it seems it still won't work. TCP/IP won't come up (DHCP or manual). So I am limited in getting software into the PM6100. Does anyone know if this is hardware failure...and where should I start to solder/unsolder stuff? As a sidenote, I tried with a SECOND PM6100 board and it seems to behave in the same way....
On a sadder note, my PowerBook 2400C woke up to the dreaded GLOD the other day....I need to find some time to fix it too.
Sitting in a room.....thinkin' shit up. :evil:
:O2: 400MHz R12k - :320: Dual 600MHz PIII - HP Alphaserver DS15 - Digital DECstation5000/133 - Dell T3500 - Apple G4 Cube dual 500MHz/GF6200 - Newton Messagepad 2100 - Apple PowerBook 2400c/G3@240 - Apple PowerMacintosh 6100/66 - Apple PowerMacintosh 6500/G3@500MHz - Apple Workgroup Server 9150/120 G3@280 - Apple Macintosh IIfx - Apple Macintosh LC475 (OC Full 040 33MHz) - Apple Macintosh Color Classic (Full 040 40Mhz Mystic upgrade) - Sun Cobalt Cube 3 - EBOX 3300A-JSK - Tadpole RDI UltraBook IIi - Compaq Armada 4120 - Digital HiNote Ultra II - HP OmniBook 425 - HP 200LX - Crossbeam C12
Re: Burnt AAUI on PM6100??
Unread postby ClassicHasClass » Fri Aug 11, 2017 9:58 pm
That definitely sounds like a hardware failure. It's probably just easier to find a NuBus card, though with what you've got in there, you may not have the room ;)
Also, I've never run the G3 and the HPV card together with a NuBus card in a 6100. I'm not even sure that's possible. I have an "SR-7100" but the 7100 is a lot less cramped to work in.
zahal
Unread postby zahal » Sat Aug 12, 2017 9:04 pm
ClassicHasClass wrote:That definitely sounds like a hardware failure. It's probably just easier to find a NuBus card, though with what you've got in there, you may not have the room ;)
The G3 card takes up the only PDS slot (where the NuBus adapter would also plug). And that would mean losing the G3 AND the HPV card.
I have a SCSI to Ethernet adapter (Dayna Pocket SCSI/Link) which I remember was kinda flaky when I last used it.
Finding a third 6100 mobo (with a working AAUI port) would be the best solution. That, and getting 4 512kb VRAM SIMMs to top the HVP.
Return to “Apple”
