Octane2, 2x400MHz, 8GB, VPro V12
ubiquityxx
Unread postby ubiquityxx » Thu Aug 10, 2017 1:25 am
Built a machine for diving back into Softimage. Mopar5150 set me up straight with all sorts of goodies. PCI cage is packed away until I need it. I found a deal on 8GB of original Kingston 2GB memory packs, unopened. Crazy lucky.
I've been configuring and fiddling all week. Soft runs wonderfully too - I'm very happy.
Octane 1# hinv -vm
      PM20400MHZ Board: barcode KWT789     part 030-1476-001 rev  D
            IP30 Board: barcode KSM290     part 030-1467-001 rev  D
             FP1 Board: barcode KBK196     part 030-0891-003 rev  G
    PWR.SPPLY.ER Board: barcode AAE0210944 part 060-0035-002 rev  A
  ODY128VERSIONB Board: barcode LJZ302     part 030-1611-001 rev  C
2 400 MHZ IP30 Processors
Heart ASIC: Revision F
Main memory size: 8192 Mbytes
Xbow ASIC: Revision 1.4
Graphics board: V12
Octane 2# /usr/gfx/gfxinfo
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL -24561
:Octane2: 2x400MHz 8GB V12 15K
HurricaneJames
Re: Octane2, 2x400MHz, 8GB, VPro V12
Unread postby HurricaneJames » Thu Aug 10, 2017 6:19 am
Nice, you even have the book.
devv
Unread postby devv » Thu Aug 10, 2017 7:13 am
I bought the book for 3 EUR + shipping. There are relatively few around (used books), but are cheap.
In mine, the seller even missed to notice that the book does contain the original CD-Rom on the inside of the back cover, maybe that reduced the price, not sure.
(The CD-Rom was there but it was turned on the other side, seemingly appearing as if the sleeve was empty.)
oOoO :Tezro: oOoO
Irinikus
Unread postby Irinikus » Thu Aug 10, 2017 7:41 am
That's one very neat Octane2 machine you've got there! :D
You were incredibly lucky to get the full complement of RAM for the machine, as I'm sure you know that the RAM for these machines is rare and usually very expensive!
Very Cool!
Image ... Image
ubiquityxx
Unread postby ubiquityxx » Thu Aug 10, 2017 7:57 am
Super duper lucky - found the 8GB of RAM for $550 + tax on ebay.
Irinikus
Unread postby Irinikus » Thu Aug 10, 2017 7:58 am
ubiquityxx wrote:Super duper lucky - found the 8GB of RAM for $550 + tax on ebay.
Very cool! :D
Image ... Image
Unread postby uunix » Thu Aug 10, 2017 12:47 pm
That is a nice machine chap, one thing I haven't been able to manage is to max out my octanes memory. Good Show.
Y888099
Unread postby Y888099 » Fri Aug 11, 2017 12:54 am
Thought it is unreasonably inflated.
So, what it the point of putting money euro in 8GB of ram for Octane?
Do you specifically need 8GB for something?
e.g.
my sweet dream was made of the perfect illusion of been able to find Ansys for IRIX.
Aiming for FEM on a middle complexity project might end consuming more than 5GB of ram.
Unread postby jan-jaap » Fri Aug 11, 2017 4:46 am
That's a very nice looking Octane2, I'm sure you'll be very happy with it.
It's true that $550 for 8GB is a lot compared to current system RAM prices. It's also a fair amount of money period, which is why my Octane2 still has the 4GB RAM it came with.
Benefit of 8GB is debatable except for corner cases, and I don't think SoftImage is one of them because as far as I know it never was a 64bit application. But hey, if it came with only 512MB and you can put your hands on 8GB ...
New price in 2001, in EUR:
HU-MEM2GB       2 GB Hauptspeicher             16.500      16.500
So 8GB is 66000 EUR ~ $77.600 (probably more in 2001 but I can't be bothered to look up historical exchange rates). So it depreciated by > 99% :mrgreen:
ubiquityxx
Unread postby ubiquityxx » Sat Aug 12, 2017 1:44 pm
8GB is a lot - it was a bit of curiosity to max out the system and see how it performs. The system is exclusively a Softimage|3D machine and shader development machine. Considering the rarity of the RAM I may pull out 4GB and keep it as backup, or put it back on the market :). Mopar5150 gave me that sage advice; he also warned about taking out the mobo as with those connectors you run the risk of damaging them - hosing the machine.
As added protection against fault I have it running on a UPS with battery backup, just in case. From what I understand you fry the mobo, the rest (cpu and memory) go along with it - eeks!
The RAM price is ridiculous but consider they don't make it anymore (so no supply), it was ECC (enterprise use=excuse to markup), it was labeled as SGI Octane memory (another excuse to markup) and freaks like me are desperate to find it (demand=more markup). Quatro whammy right there which is why is costs so dag much. I got super duper lucky.
No matter - I'm happy :)
HurricaneJames
Unread postby HurricaneJames » Sat Aug 12, 2017 1:47 pm
I think I saw a dual 600mhz cpu on eBay the other day. If you risk taking out the mobo to reduce the ram, you can do an upgrade on the couch at the same time.
Dalplex
Unread postby Dalplex » Sat Aug 12, 2017 8:52 pm
Does that CD-ROM come with 68pin connector?
ubiquityxx
Unread postby ubiquityxx » Sat Aug 12, 2017 10:09 pm
I believe the CD-ROM enclosure has 2 big ol' centronics 50 pin connectors. The cable goes from 50pin to high density 68pin.
