My first 320
Hombre71
My first 320
Unread postby Hombre71 » Wed Aug 02, 2017 7:31 am
For your (and mine) entertainment.
Noisy scsci harddisk and fan, but otherwise nice spec.
Now to find a1600sw adapter for the box...
Irinikus
Re: My first 320
Unread postby Irinikus » Wed Aug 02, 2017 7:45 am
Nice one!
You're lucky you got it with dual processors and with a VRM fitted, as the VRM's for these machines can be rather hard to come by!
Image ... Image
johnnym
Re: My first 320
Unread postby johnnym » Wed Aug 02, 2017 8:21 am
Hombre71 wrote:For your (and mine) entertainment.
The CPUs look like Pentium II or Pentium III in SECC2 cartridges.
Ah, I see, dual Pentium III 550 MHz, so Katmais (Model 7 and 512 KiB Cache). Say, could you have a look on the used VRM to check who manufactured it and what P/N it has?
Do you have faced any crashes with Windows 2000 on this machine so far? Any special patches applied?
Congratulations, btw. :)
HurricaneJames
Re: My first 320
Unread postby HurricaneJames » Wed Aug 02, 2017 8:34 am
I have been looking for a reasonably priced MLA for a while, been thinking about trying to hacking something together with an LVDS board (ex. http://www.ebay.com/itm/161320408901 ). Maybe one day, when I have time to play around again.
Irinikus
Re: My first 320
Unread postby Irinikus » Wed Aug 02, 2017 8:48 am
johnnym wrote:Say, could you have a look on the used VRM to check who manufactured it and what P/N it has?
The VRM in my machine is a: Celestica 073-20770-01 if this helps.
Image ... Image
johnnym
Re: My first 320
Unread postby johnnym » Wed Aug 02, 2017 11:48 am
So a 073-20770-01 actually also works for the Visual Workstation 320 with dual CPUs installed. That's good to know. I remember that FlasBurn tried such a VRM in his VW 320 without luck - no stable SMP operation with Windows 2000 (not even during installation).
Do you have Windows 2000 installed on yours? And does it run stable for you?
Dalplex
Re: My first 320
Unread postby Dalplex » Wed Aug 02, 2017 12:32 pm
What a unique ram .
Irinikus
Re: My first 320
Unread postby Irinikus » Wed Aug 02, 2017 1:12 pm
johnnym wrote:So a 073-20770-01 actually also works for the Visual Workstation 320 with dual CPUs installed. That's good to know. I remember that FlasBurn tried such a VRM in his VW 320 without luck - no stable SMP operation with Windows 2000 (not even during installation).
I do run Windows 2000 on the system and it has dual PIII 1 GHz processors fitted. It does seem to run stable, but I don't use the machine that often, so I cant say that its completely stable.
It's stable enough to play games tough! :D
Here are some pics showing the system information:
Image ... Image
Irinikus
Re: My first 320
Unread postby Irinikus » Wed Aug 02, 2017 1:35 pm
You've got a really cool machine, now all you need to do is find a Pair of 1 GHz PIII's and your system will run like a machine! :D
Image ... Image
Hombre71
Re: My first 320
Unread postby Hombre71 » Thu Aug 03, 2017 12:49 am
Finding the matched pair of PIII Slot 1's @100mhz will also take some time. Good for my wallet also :)
Hombre71
Re: My first 320
Unread postby Hombre71 » Thu Aug 03, 2017 12:51 am
HurricaneJames wrote:I have been looking for a reasonably priced MLA for a while, been thinking about trying to hacking something together with an LVDS board (ex. http://www.ebay.com/itm/161320408901 ). Maybe one day, when I have time to play around again.
What would that entail? Interesting looking board. With the scareness and prices for the MLA a small batch might be interesting for some here....
Hombre71
Re: My first 320
Unread postby Hombre71 » Thu Aug 03, 2017 5:20 am
According to this table:
http://www.frontlinemedia.de/sgi320/vrm.html
That the 20770 works is an expected outcome :)
johnnym
Re: My first 320
Unread postby johnnym » Thu Aug 03, 2017 5:41 am
Hombre71 wrote:According to this table:
I remember this table, but the page is not very explicit in stating that the VRM types listed in the table are working or were tested in a VW 320. But maybe I misunderstand/stood it in the past, because the last sentence could as well be understood that way, i.e. that all VRMs conforming to VRM 8.3 or VRM 8.4 specifications are working for dual 1 GHz Pentium III in the VW 320. :?
Hombre71
Re: My first 320
Unread postby Hombre71 » Fri Aug 04, 2017 9:51 am
Just had a closer look at the mainboard, it has the stickly label and is
revision 117....B! 29-mar-1999 say the other sticker.
Hombre71
Re: My first 320
Unread postby Hombre71 » Fri Aug 04, 2017 10:00 am
The vrm in my 320 is a Celestica 073-20742-30 Rev:F
