Indigo 2 R10k 175mhz 256mb
weGuru
Unread postby weGuru » Sun Jul 16, 2017 7:16 pm
impact 2# hinv -vm
1 175 MHZ IP28 Processor
Main memory size: 256 Mbytes
On-board serial ports: 2
Graphics board: Solid Impact
EISA bus: adapter 0
impact 4# /usr/gfx/gfxinfo -vv
        Product ID 0x1, 1 GE, 1 RE, 0 TRAMs
        VC3 rev A, CMAP rev EMC rev D
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  unknown
:Indy: R4600 :Indy: R4600 :Indy: R5000 :Indigo2IMP: R10k :O2: R5000 :Octane: R10k :Indigo: R4400
Sun Ultra 10, Sun 220R, Sun 420R, Sun 670MP, Sun E250, Sun IPC, Sun Ultra 60, Sun Ultra Ent 2, Sparcserver 5, IBM R/S 6000 model 590, DEC Vaxstation 4000/90
Re: Indigo 2 R10k 175mhz 256mb
Unread postby Trippynet » Mon Jul 17, 2017 12:55 am
Nice little system, you don't see too many of the 175MHz R10ks in Indigo2s.
