Octane R10K 195mhz 256mb
Unread postby weGuru » Sun Jul 16, 2017 6:58 am
octane 1# hinv -vm
            PM10 Board: barcode DZK234     part 030-0888-004 rev  E
            IP30 Board: barcode DKV772     part 030-0887-003 rev  F
    PWR.SPPLY.ER Board: barcode AAE8370680 part 060-0035-001 rev  B
             FP1 Board: barcode EBK158     part 030-0891-003 rev  B
            GM10 Board: barcode EBL718     part 030-0938-003 rev  S
1 195 MHZ IP30 Processor
Heart ASIC: Revision D
Main memory size: 256 Mbytes
Xbow ASIC: Revision 1.2
Graphics board: SI
octane 2# /usr/gfx/gfxinfo -vv
        VC3 rev A, CMAP rev E, Heart rev D
:Indy: R4600 :Indy: R4600 :Indy: R5000 :Indigo2IMP: R10k :O2: R5000 :Octane: R10k :Indigo: R4400
Sun Ultra 10, Sun 220R, Sun 420R, Sun 670MP, Sun E250, Sun IPC, Sun Ultra 60, Sun Ultra Ent 2, Sparcserver 5, IBM R/S 6000 model 590, DEC Vaxstation 4000/90
