Indy R5K 150mhz 128MB
weGuru
Unread postby weGuru » Sun Jul 16, 2017 6:50 am
indy5k 6# hinv -vm
CPU: MIPS R5000 Processor Chip Revision: 1.0
FPU: MIPS R5000 Floating Point Coprocessor Revision: 1.0
1 150 MHZ IP22 Processor
Main memory size: 128 Mbytes
Secondary unified instruction/data cache size: 512 Kbytes on Processor 0
On-board serial ports: 2
Graphics board: Indy 24-bit
Iris Audio Processor: version A2 revision 4.1.0
Vino video: unit 0, revision 0, IndyCam connected
indy5k 7# /usr/gfx/gfxinfo -vv
Graphics board 0 is "NG1" graphics.
        24 bitplanes, NG1 revision 6, REX3 revision B, VC2 revision A
        MC revision C, xmap9 revision A, cmap revision D, bt445 revision D
        Display 1280x1024 @ 60Hz, monitor id 15
:Indy: R4600 :Indy: R4600 :Indy: R5000 :Indigo2IMP: R10k :O2: R5000 :Octane: R10k :Indigo: R4400
Sun Ultra 10, Sun 220R, Sun 420R, Sun 670MP, Sun E250, Sun IPC, Sun Ultra 60, Sun Ultra Ent 2, Sparcserver 5, IBM R/S 6000 model 590, DEC Vaxstation 4000/90
