vlan.h ?
Zerolapse
vlan.h ?
Unread postby Zerolapse » Sat Jul 08, 2017 8:12 pm
Anyone have any idea what library provides dmedia/vlan.h? This would be vlan as in video lan, not virtual lan.
I'm trying to debug an audio issue with avcapture, but the vlan library doesn't seem to be part of the dmedia example source that I installed.
Thanks!
-Jesse
The current fleet.
jpstewart
Re: vlan.h ?
Unread postby jpstewart » Sun Jul 09, 2017 8:45 am
All of the video LAN stuff is in the vlan product. Specifically, you'll need the vlan.sw.dev subsystem to get that header file. I believe it is on the "Applications" CD of the IRIX installation set.
HP C8000
Digital DECstation 5000/125
Zerolapse
Re: vlan.h ?
Unread postby Zerolapse » Sun Jul 09, 2017 9:52 pm
You were correct, though at first I didn't believe you were!
The vlan.sw subsystem didn't exist on the Applications CDs that shipped with 6.5.22-6.5.30. I had to dust off an old SCSI CD-ROM drive and dig out my old IRIX CDs to go all the way back to the Applications CD from May of 1999, which shipped with my 6.5.4 CD set.
In any case, it seems to work fine on 6.5.30 and I'm now able to compile avcapture successfully. Now to figure out why it's not working for me.
Thanks for the hint!
-Jesse
The current fleet.
