FUEL V12 R16000 800MHz 4GB
Unread postby uunix » Sat Jun 24, 2017 3:07 am
I thought I had done a hinv for this machine some years back. Can't find it and now it's had a V12 fitted. Apart from the CPU could go up a notch to 900MHz (which I couldn't see a need), this machine is pretty top notch now,V12, LTO tape, DM6 (Pointless so far) etc
1 800 MHZ IP35 Processor
CPU 0 at Module 001c01/Slot 0/Slice A: 800 Mhz MIPS R16000 Processor Chip (enabled)
Main memory size: 4096 Mbytes
Integral SCSI controller 3: Version SAS/SATA LS1068
  Tape drive: unit 8 on SCSI controller 0: unknown
Graphics board: V12
Gigabit Ethernet: eg0, module 001c01, pci_bus 1, pci_slot 3, firmware version 0.        0.0
  PCI Adapter ID (vendor 0x10ee, device 0xd151) PCI slot 1
  PCI Adapter ID (vendor 0x1000, device 0x0054) PCI slot 2
  PCI Adapter ID (vendor 0x10a9, device 0x0009) PCI slot 3
SD-DIGVID Standard Definition Digital Video: unit 0, revision 2.75.0
USB controller: type OHCI
and video
        Managed (":0.0") 1600x1200
        BUZZ version B.1
        PB&J version 1
        128MB memory
                Banks: 4, CAS latency: 3
         Monitor 0 type: DEL -24544
         Video Output: 1600 pixels, 1200 lines, 59.83Hz (1600x1200_60)
johnnym
Re: FUEL V12 R16000 800MHz 4GB
Unread postby johnnym » Sat Jun 24, 2017 4:18 am
Pictures please! :)
Unread postby Trippynet » Sat Jun 24, 2017 8:21 am
Very nice system indeed!
Unread postby vishnu » Sat Jun 24, 2017 6:52 pm
Deluxe! :mrgreen: Can I have it? :lol:
