My latest in deep personal stupidity...
scottE
Unread postby scottE » Thu Jun 15, 2017 2:09 pm
So I've managed to bork X windows on my Indy, possibly by following these instructions here, but probably not to the letter.
So when I rebooted Helicoprion, I get the usual screens on startup, and then an unhelpful black frame once it logs into the user account.
I've been … away, so it's hard to remember what I can/should do at this point. So I tried fiddling with sash from the PROM Monitor. But I can't for the life of my figure out how to copy over the edited Xservers file with my backup, made just before I fiddled with stuff.
This would be easier if I could put it on a network, but I cannot in this case. I also do not have access to anything that could function as a dumb terminal (one of the things I was actually trying to do was get the Indy to have cu installed to fulfill that function, but I was distracted before I could get that to work).
So from the stand alone shell it's not:
cp /var/X11/xdm/Xservers.backup /var/X11/xdm/Xservers
or
cp dsk(0,1,0):/var/X11/xdm/Xservers.backup /var/X11/xdm/Xservers
or
cp dsk(0,1,0):/var/X11/xdm/Xservers.backup dsk(0,1,0):/var/X11/xdm/Xservers
or
cp dsk(0,1,0)|/var/X11/xdm/Xservers.backup dsk(0,1,0)|/var/X11/xdm/Xservers
or
cp /var/X11/xdm/Xservers.backup:dsk(0,1,0) /var/X11/xdm/Xservers
Or any variation thereof, and help in sash is really useless.
Anyone know how I can fix this?
Scott Elyard cgfx.us
Black Cardinal
Re: My latest in deep personal stupidity...
Unread postby Black Cardinal » Thu Jun 15, 2017 2:30 pm
Even if X isn't working, you should still be able to remotely log in over the network, or use the serial console. From a regular shell prompt shut down the Xserver with /usr/gfx/stopgfx, copy the backup files into place, and then restart X with /usr/gfx/startgfx.
Black Cardinal
scottE
Unread postby scottE » Thu Jun 15, 2017 4:19 pm
Black Cardinal wrote:you should still be able to remotely log in over the network, or use the serial console.
Alas, neither of these are an option.
miod
Unread postby miod » Thu Jun 15, 2017 10:38 pm
Why not boot single user ("stop for maintainance" on powerup, then get a prompt and enter "single"), mount your disks, and cp from the single-user shell?
scottE
Unread postby scottE » Fri Jun 16, 2017 11:22 am
miod wrote:Why not boot single user ("stop for maintainance" on powerup, then get a prompt and enter "single"), mount your disks, and cp from the single-user shell?
Perfect! Thank you! That solved the issue. (Though I didn't have to mount anything, just log in. And I used mv instead of cp.)
To be honest, I'd long forgotten that was even an option. But I've been trying to bring up Carcharodon, and I lack access to a terminal of any sort.
