Indigo2, R10000 195 MHz, 320 MB, High Impact AA, 100Mbps NIC
Pain
Unread postby Pain » Wed Jun 14, 2017 4:08 am
My second SGI machine:
# hinv -vm
1 195 MHZ IP28 Processor
Main memory size: 320 Mbytes
On-board serial ports: 2
Graphics board: High-AA Impact
EISA bus: adapter 0
# /usr/gfx/gfxinfo -vv
        Managed (":0.0") 1024x768
        Product ID 0x0, 2 GEs, 1 RE, 1 TRAM
        MGRAS revision 2, RA revision 5
        HQ rev A, GE11 rev A, RE4 rev A, PP1 rev A,
        VC3 rev A, CMAP rev DMC rev D
        19" monitor (id 0x1)
         Video Output: 1024 pixels, 768 lines, 59.96Hz (1024x768_60)
         Video Format Flags:  (none)
         Sync Disabled
         Using Gamma Map 0
         Monitor Type:  SONY-GDM-20E21
Monitor type is wrong, it's a Philips Brilliance 150P, connected to a SUN 13W3 VGA-Adapter, H/V sync-pins on the VGA-connector cut off for proper sync on green.
# scsicontrol -i /dev/scsi/*
/dev/scsi/sc0d1l0:  Disk          COMPAQ  BD072863B2      HPB4
Device is  ready
uname -aR
IRIX64 shirone 6.5 6.5.22f 10070055 IP28
My DALLAS RTC-battery is dead, the machine refuses to use XGA-resolution in PROM. Except of these the machine is working fine.
I gifted my other R4400-Indigo2 to another workstation lover. :)
:Indigo2IMP: Indigo² - R10000 195 MHz - 320 MB RAM - 72 GB HDD - 10/100 NIC - High Impact AA
jpstewart
Re: Indigo2, R10000 195 MHz, 320 MB, High Impact AA, 100Mbps NIC
Unread postby jpstewart » Wed Jun 14, 2017 8:21 am
Oooh, that's a nice machine. Especially the graphics. You don't see the High Impact AA very often. Congratulations, and I hope you have lots of fun with it!
Sun SPARCstation 20, Blade 2500, T5240
HP C8000
